Jeep build take two!!!!!
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
| View Poll Results: What have you done to your 258 engine | |||
| Rebuilt stock |
11 | 12.09% |
| Rebuilt with 4.0 head |
13 | 14.29% |
| replaced |
18 | 19.78% |
| Still hoping it starts in the morning |
49 | 53.85% |
| Voters: 91. You may not vote on this poll | |||
#46 | |
nice engine, rebuilt my old 4.0 too last week.
#47 |
How easy was the gauge swap? Did the mfg have a wiring harness to existing wiring? Or did you have to cut up the original harness?
Thanks |
#48 | |
Why am I here?
Be careful over there and return safe! Z |
#49 | |
Easy to do, like I said above just use the old gauge cluster as a wire diagram, it is easy to trace the runs. I just cut the stock jeep connector off and soldered the new wires in....
1989 YJ 258CI 4.2L with 4.0-HO(7120)5 angle head job, Comp-Cam 4x4 xtreme cam, Holley 4412 500CFM Carb, Clifford performance single Plenum intake, CRT HEI distributor, Rough country 4" lift, 33.5 tires, Ultra Polished Aluminium Rims, Warn Powerplant, Galaxy DX-979 w/ a little help-x-250, custom tire swingout rear bumper, quick disconnects, Posi-Loc, new paint. My build thread: http://www.jeepforum.com/forum/f12/jeep-build-take-two-642379/ |
#50 |
how did you do the serpintine belt set up?i would like to do this to my 258.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000 |
#51 | |
If you have a 90 YJ you should already have a serpintine belt???? but if you have the straight belts than it is just a matter of getting a reverse flow water pump and the pulleys off of a 258 tat had a serpintine. If you are talking about the 4.0 head swap it is the same as the standard head you just have to make a new bracket for the power steering pump. You can simply add a small piece of metal to the top of the existing bracket and drill new holes..
1989 YJ 258CI 4.2L with 4.0-HO(7120)5 angle head job, Comp-Cam 4x4 xtreme cam, Holley 4412 500CFM Carb, Clifford performance single Plenum intake, CRT HEI distributor, Rough country 4" lift, 33.5 tires, Ultra Polished Aluminium Rims, Warn Powerplant, Galaxy DX-979 w/ a little help-x-250, custom tire swingout rear bumper, quick disconnects, Posi-Loc, new paint. My build thread: http://www.jeepforum.com/forum/showthread.php?t=642379 |
#52 |
Finally coming home!!!!! Leaving Iraq this week. I can not wait to get back to working on the Jeep and driving it.... I built it right up until I left for Iraq and never really got to have any fun with it. Now it is time to see what I can break. Most of the work I am going to do now is custom fabrication, bumpers etc.... I think I am going to treat myself to some new toys. I am looking into getting a Plasma cutter and a Pipe bender.
The art of justification: I figure that a new set of bumpers that i like, Garvin style, will cost around 1500.00. Just so happens that is about what a Miller 625 X costs. The roll cage to keep my family safe will run me at least 1K for a good kit and as luck would have it a bender with a 1 3/4 die set is around 800.00 funny how these things work out!!!Right now I have some new stuff waiting for me in boxs at the house. 1 new rear seat, besttop trailmax 2 (the new rig came without one) new seatbelts New Stereo some grab handles and a nice new Jeep hat!! After installing that stuff I will move on to the following: Roll cage rear bumper front bumper rock guards skid plates I am really interested in taking on a custom dash, I was toying with the idea of intergrating the center console with the dash for more of a buggy feel. Just looking for somthing a little different. J
#53 |
i love this build!! welcome home!!! i have been planning on doing the exact same setup that you have for a while. btw... def. do the dash/console thing. it will look awesome.
1990 yj, 4.2, ax-15, 2.5" RC lift, 1/2" boom shackles, Herculiner inside, duplicolor outside, 33x12.50-15 Interco trxus mt's, Hacked body, "The right of the people to keep and bear Arms shall not be infringed." |
#54 |
Autometer rewire, done right
I finally got around to reworking the gauges. I put them in fast so I could get my engine running. I took an old computer power supply and used the 4 pin connectors to make the two connections. One is for the gauge lights and 12V power and the other 4 pin is for the sensor lines. One other thing I did was mount a small 1/8" rod to the oil gauge, I taped it to the base and than taped the tube to it about 1" out in order to prevent a kink in the line when putting it in an out. I am real happy with this setup since I can now pull the entire gauge pod out with 2 quick disconnect connectors and unscrewing the oil and air line.
#55 |
Awesome build! I am gathering some info for my own build similar to this, what did you use for your throttle cable?
What made you pick the Holley 4412? Any reason to not go 4bbl? What about TFI vs the HEI? What pistons did you run? Thanks for all of the great info!!! |
#56 |
Very nice build! What springs did you use for your comp cam?
Thanks, B |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
