Quantcast Jeep build take two!!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep build take two!!!!!
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
View Poll Results: What have you done to your 258 engine
Rebuilt stock 11 12.09%
Rebuilt with 4.0 head 13 14.29%
replaced 18 19.78%
Still hoping it starts in the morning 49 53.85%
Voters: 91. You may not vote on this poll
Old 12-02-2008, 08:37 PM   #1
johnrezz
Well after replacing the engine in my jeep to find out the replacement was bad I decided to have my old engine rebuilt. I took it over to JTR Precision Engines in Craig Colorado to have the work done ( http://www.jtrengines.com ) Instead of just doing your run of the mill rebuild we decided to do a 4.0 head swap, put a new cam in and some other goodies..... Here are the first pictures of the project.
Block: cleaned and ready to be milled
Valve cover: This is a stock valve cover that looked like garbage when I gave it to them, what a difference
Old bearings, ohh baby, not to surprising that this engine sounded like it was full of legos... some new ones for comparison.
Obviously from the last photo I have a Crank issue, I will let you know what the crank grinder has to say....
More to come:
1989 YJ 258CI 4.2L with 4.0-HO(7120)5 angle head job, Comp-Cam 4x4 xtreme cam, Holley 4412 500CFM Carb, Clifford performance single Plenum intake, CRT HEI distributor, Rough country 4" lift, 33.5 tires, Ultra Polished Aluminium Rims, Warn Powerplant, Galaxy DX-979 w/ a little help-x-250, custom tire swingout rear bumper, quick disconnects, Posi-Loc, new paint.
My build thread: http://www.jeepforum.com/forum/f12/jeep-build-take-two-642379/
johnrezz is offline   Reply With Quote
Old 12-02-2008, 09:00 PM   #2
Jkanly
Ouch! I'd say from the way those bearings look, your crank is shot.
"Energizer Bunny arrested, charged with battery" - Jay Leno
l _____
/l
,[____],
l---L –0lllllll0-
()_)-()_)--o-)_)
~ Do it right or don't do it at all ~
Jkanly is offline   Reply With Quote
Old 12-02-2008, 09:43 PM   #3
girly04LJ
2009 JK Wrangler
This might sound like the expensive thing to do but it looks like a good time to build a stroker. My husband built one for our old YJ and after having one it's hard to even deal with a H.O.4.0L much less a 258. When he was getting quotes for a rebuild the only diffrence was $200 bucks worth of doner engines and $150 for balancing the parts so if you do it yourself it's not that bad. Plus you get a sweet motor that can almost keep up with all the stock V8s
girly04LJ is offline   Reply With Quote
Old 12-02-2008, 11:07 PM   #4
SonoraDetective
Junior Member
SonoraDetective's Avatar
stroke it
I have a 4.7L stroker in my red jeep. It can stomp the arse of several small blocks...lol
Stroker stroker
SonoraDetective is offline   Reply With Quote
Old 12-03-2008, 07:34 AM   #5
wendell
1987 YJ Wrangler
Thats what I like about the 258, it's so versitle. You can run a 1 barrel, 2 barrel, or 4 barrel or carb, you can run tb injection or multi port. You can stroke it, cam it, do the 4.0 head, the possabilites are endless, "well", not endless, but you get the idea. I did the holley 4 barrel, just to be different instead of efi, did an old school build with cam, header and what have you. It's a fun motor to play with.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote
Old 12-03-2008, 08:19 AM   #6
johnrezz
I thought about doing the stroker but I did not have a 4.0 donor and I had already purchased about 700 bucks worth of upgrades to my 258 before it popped....
And yes the crank is pretty much shot. I have a second 258 block with a good one that I may pull......
John
My build thread: http://www.jeepforum.com/forum/showthread.php?t=642379
Old 12-18-2008, 08:34 PM   #7
johnrezz
Updated pics
I got some updated info on my rebuild so I thought I would share the images.
Here is my Crank after grinding an polishing:
Here is the block bored out .020:
Here is a picture of the guides being milled:
Seals instaled:
Springs:
These pictures were sent to me by Jorin over at JTR Performance engines, check out the website if you get a chance
http://www.jtrengines.com/
I hope to get the Jeep into the Garage to prep it for the new engine over the next couple of weeks. The snow has arrived here in NW Colorado so my Jeep will not get much use for awhile. But I can't wait for spring to try it out....
John
Old 12-18-2008, 08:46 PM   #8
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
i just wanted to now if you noticed the crack in the block?
just kidding, what do you think the cost is compared to buying a long block?
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Old 12-19-2008, 08:11 AM   #9
johnrezz
much better value.... It is going to cost me somewhere around 1350 for this rebuild. with shipping and core exchange it would wind up costing me the same for a reman, or more...... This way I have a quality shop building my engine, I can pick the components I want, I am having the head swapped to a 4.0 and I have someone to physically goto if I have a problem.
I have seen some horrible crate motors in the past, matter of fact the guys building my engine have a 350 Crate engine that a customer brought in to have some work done and it was so poorly built it had to be redone.....
I would always reccomend this route. For the simple reason that you will know exactly what you got when you are done....
If you are near NW Colorado, check these guys out...
www.jtrengines.com
Old 12-19-2008, 09:38 AM   #10
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
What would you save if you just had them do the machine work,
The last time i rebuilt a motor was a 327 in my 69 chevy van, in 1974. i havnt had a motor blow since. Dam that synthetic oil wont let me have any fun. i was taking a small engine repair class at the local college, which was supposed to be working on lawn mower motors. The instructor let me do my v8 in the class.
Old 12-19-2008, 09:19 PM   #11
johnrezz
sure
Yeah, that would be good.... I just do not have the time to take on a project like that. It would save alot of money. I opted for the route I went because I know these guys know what they are doing and I am going to get a rocking engine when they are done...
John
Old 12-20-2008, 09:15 AM   #12
johnrezz
Ok so I decided against installing the Roller Rockers since we could not find a cheap alternative to a retail set. We decided that the money would be much better spent in a new Clifford performance intake. Bang for the buck it is going to produce much more HP than the rockers...... I can always add them later if I wanted to.....
John
Intake:
Old 01-01-2009, 10:18 AM   #13
johnrezz
engine updates
Here are some pics of the steps taken to improve my Rods although they were in pretty good shape considering the engine had spun some bearings:smokin:.
The work is being done by:
http://jtrengines.com
-2 rods as removed and pressed off of the pistons
-Rods with old bolts removed, blasted, and ready for cap grinding, assembly with new bolts and machining
-ARP Hi-Perf 8740 bolts (around 200,000 psi tensile strength) compared to stock ones (around 150,000 psi tensile strength)
-Ready for initial assembly, torquing of the new bolts and machining
-Machined rod ready to be assembled to the piston and go into the engine.
Old 01-01-2009, 10:30 AM   #14
wildman90
looking good. you may want to take a flap wheel to the casting flash on the side of those rods. polish it up and make it smooth all over. all the little sharp edges are stress risers and make the part weaker. you could do the same thing to inside of the engine as well.
keep us updated
nothing i cant do--i'l pay myself $50/hr labor!!
the only thing you cannot do, is that which you have already accepted defeat!
many people search for god in the eleventh hour, only to die at 10:30
wildman90 is offline   Reply With Quote
Old 01-01-2009, 10:06 PM   #15
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
whats the increase in hp you will get when your done.
this thread seems like a back door advertisement for the machine shop.but i won't tell!
Glock Forum
