Jeep all over the road after 4" lift install - JeepForum.com
post #1 of 14 Old 01-10-2010, 03:30 PM Thread Starter
CTJeepin
1987 YJ Wrangler
Hey guys...I installed my RC 4" lift last month. Everything went smooth but I notice that now, every time I go over 40mph, I have to do everything possible to control the Jeep. It's not a wobble, but more of a serious left-to-right sway. I find myself having to constantly overcorrect the steering wheel just to stay in my lane.
I did a thorough search of the forum before posting this and the only thing that I could find were posts about making the tie rod and drag link more parallel to one another by doing the tie rod flip. After installing my drop pitman arm, the drag link doesn't seem to be at an extreme enough angle to cause this degree of swaying, but I could be wrong. Also, there is no play in the steering box. I've posted some pics of my front end. Sorry, but I haven't mastered the click-free feature yet.
If this helps at all, I haven't gotten the front end aligned yet, and the steering stabilizer is stock from 1987 so it likely isn't doing its job properly. Maybe this could be adding to the problem but I'd like your thoughts. Thanks!
http://i58.photobucket.com/albums/g2...a/frontend.jpg
http://i58.photobucket.com/albums/g2.../pitmanarm.jpg
http://i58.photobucket.com/albums/g2...a/passside.jpg
CTJeepin is offline
post #2 of 14 Old 01-10-2010, 03:37 PM
Fhajad
Do you have a steering dampener in there?
Fhajad is offline
post #3 of 14 Old 01-10-2010, 03:40 PM
Straycur
Krikees! you better get the clamp back over the pax side TRE before it falls out. That thing is is probably flexing more than the Governator! A couple other things to check are your tire pressure and toe in.
Straycur is offline
post #4 of 14 Old 01-10-2010, 03:44 PM Thread Starter
CTJeepin
1987 YJ Wrangler
I have the stock stabilizer in there but I'm not sure how good of a job it's doing because of its age.
CTJeepin is offline
post #5 of 14 Old 01-10-2010, 03:48 PM
gmiller0737
As stated above move that clamp (In your 3rd pic) back where it belongs,Are the shackles part of the lift? From your description of the way it handles it sounds like there is not enough Caster have your alignment checked on a machine & post the readings.
gmiller0737 is offline
post #6 of 14 Old 01-10-2010, 03:55 PM Thread Starter
CTJeepin
1987 YJ Wrangler
Will do; good catch guys. I loosened it to back out the tie rod end a few turns because the steering wheel wasn't centered and completely forgot to put it back and tighten it. The shackles are stock.
CTJeepin is offline
post #7 of 14 Old 01-10-2010, 06:54 PM
Mark05059
you moved your steering wheel by moving the TRE?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 14 Old 01-10-2010, 07:10 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
I might be wrong, but it's the drag link that gets adjusted from what I remember. By moving the TRE, you are either pointing your tires more IN or more OUT....causing severe drift and your TRE being loose is most likely going in and out of whack while driving.
I recommend getting a new steer damper (they be el cheapo) and taking it to get aligned PDQ.
And Mark05059 being from Queechee just made me think of an old friend from there that used to scream QUEECHEE with me when we were drunk...ah..the memories...I loved the 89/91 area.
hotelconucc93 is offline
post #9 of 14 Old 01-10-2010, 07:11 PM Thread Starter
CTJeepin
1987 YJ Wrangler
I meant to say drag link end.
CTJeepin is offline
post #10 of 14 Old 01-10-2010, 07:14 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
A steering damper is a complete waste, I have never ran one. A properly set up front end with no worn parts doesn't need one at all. I haev ran upto 37's on the road with out them for years.
I would say that your geometry is screwed up. Either measure it yourself or take it to an alignment shop that handles 4x4's. Too little caster will do what you are describing.
Set the toe @ 1/8" toe in.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #11 of 14 Old 01-10-2010, 07:16 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
In your 2nd pic, what is that hose / cable looking thing hanging down by the front spring?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #12 of 14 Old 01-10-2010, 07:19 PM
Blackfish
Do a little self alignment, jack the front up and measure the rear center to center of the tires then moved to the front you are looking for an 1/8 of an inch toe in, while you have it up check for side to side play, also the steering stabilizer may leak a little if its bad, the tierod ends may be loose or joints bad..
My boss made the comment that "I bet you missed me over the holiday break",my response was "yes your right I did, but my aim is getting better"
Blackfish is offline
post #13 of 14 Old 01-10-2010, 07:24 PM Thread Starter
CTJeepin
1987 YJ Wrangler
I think it's the axle breather hose.
CTJeepin is offline
post #14 of 14 Old 01-10-2010, 07:27 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Hmm thats what it looks like. Not part of your current issue, but it should be up a little higher.
-Matt
White '94 YJ Sport
UltimatE is offline
Zone off road 3" lift -vs- RC's 2.5" DISCUSS CCJ TJ Wrangler Technical Forum 36 11-06-2011 08:04 PM
road wondering after Rough Country 2.5 spring lift install nycrd JK Wrangler Technical Forum 8 03-19-2009 05:29 PM
gettin my jeep "off-road ready"..few questions chriscisme YJ Wrangler Technical Forum 16 02-19-2008 01:43 PM
Jeep goes off-road for inroads "USAToday Article" Chewee TJ Wrangler Technical Forum 3 11-18-2003 07:18 AM
Best on-road/off-road performance 2" lift 32" tire combo Bryan_16 TJ Wrangler Technical Forum 18 08-15-2002 11:02 AM
