Jeep #6 - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep #6
All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!
Unread 12-30-2013, 03:29 PM   #61
Que89YJ
Pm me if I miss your post and don't post back. Sounds like you're making good progress.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 12-30-2013, 03:34 PM   #62
2jeeps1stang
1987 YJ Wrangler
Thanks man I appreciate all your help thus far
87 yj wrangler, 4.0, lifted, 33s. Slowly taking jeep 'roids.
75 cj5 304, Fiberglassed, 4:56, lift, 35s
73 cj5 built 401
2jeeps1stang is offline   Reply With Quote Quick reply to this message
Unread 01-08-2014, 01:31 PM   #63
2jeeps1stang
1987 YJ Wrangler
Que, I took the heat gun to the fuel tail and injectors this morning. Started up fine and idled fine for about 2 minutes then went to being rough again. A friend of mine can get new parts at cost. So I think starting with the injectors isn't a bad idea. It's the only thing minus the pump I haven't changed on this damn thing
73 cj5 built 401
Unread 01-08-2014, 02:56 PM   #64
Que89YJ
Don't replace them thinking they are going to fix it. Replace the o2 sensor and check the manifold for leaks. That lean fault is definitely pointing to something that makes sense with you symptoms. The injectors don't really make sense.
Unread 02-01-2014, 12:50 AM   #65
2jeeps1stang
1987 YJ Wrangler
Update: revisited the IAC and coolant temp seņor via que's recommendations. That and cleaning out the IAC housing/throttle body may have helped. Either way. It has been fine all this week. Upon cold start ups, better mileage, and no stumbling. I am deeming this fixed.
To treat myself I ordered some bilstein 5100 for the rear as my old worn out hydros are leaking.. Go figure. I also needed to get a new Trans stabilizer bolt with bushings. Lastly, I sourced some take off skyjacker quick disconnects that are like new.
To finish off January my vacuum actuator was busted for the 4x4 so to get by until spring, I pulled the whole unit off the front axle. Slid the collar over both axel shafts. Flipped the whole unit 180 degrees and bolted it back on. Done. 10 minute fix to get by until the weather breaks.
73 cj5 built 401
Unread 02-01-2014, 05:18 AM   #66
Que89YJ
Thanks for posting the fix.
Unread 02-01-2014, 08:12 AM   #67
2jeeps1stang
1987 YJ Wrangler
Thought I was gonna have to perform and exorcism on it. Thing has a mind of its own I am convinced. Thanks again for all your help man.
73 cj5 built 401
Unread 03-08-2014, 09:52 PM   #68
2jeeps1stang
1987 YJ Wrangler
Ordered some LEDs off amazons. 10$. Needed 2 for the tach. 2 for the speedo. 4 for the center gauges and 1 for the hvac
73 cj5 built 401
Unread 03-09-2014, 10:44 AM   #69
ownTer
Very nice. Im doing the LED dash lights here soon. Got a link the ones you used?
The jeep is looking sharp. What is next for it?
ownTer is offline   Reply With Quote Quick reply to this message
Unread 03-09-2014, 01:08 PM   #70
jamison
I second that request for the led link.
jamison is offline   Reply With Quote Quick reply to this message
Unread 03-09-2014, 06:37 PM   #71
2jeeps1stang
1987 YJ Wrangler
Thanks fellas. Next plans are get new headlights, finish rear tube fenders, and rock sliders and paint. Thursday I will be putting the front bilstein 5100s on and new steering stabilizer.
Here's the link. To my knowledge they will work in the dome light as well.
http://www.amazon.com/gp/aw/d/B00877..._26725410_item
73 cj5 built 401
Unread 03-13-2014, 10:10 PM   #72
2jeeps1stang
1987 YJ Wrangler
Front shocks are on. Bilsteins make the yj much softer on the road. Yes ... It's still a yj and the ride sucks but there is definitely a discernible difference in comfort now. I would highly recommend them
73 cj5 built 401
Unread 03-14-2014, 10:17 PM   #73
2jeeps1stang
1987 YJ Wrangler
Skyjacker 9000 steering stabilizer. Love the response it gives worth the $45. Came with the hardware too.
73 cj5 built 401
Unread 04-05-2014, 12:03 AM   #74
2jeeps1stang
1987 YJ Wrangler
Well, shackle mount up front broke on me. Also found out my driver's side shackle was cracked. So currie's are on their way and I torched a mount off our parts jeep to weld up tomorrow night once I get it cleaned up. Also, included a pic of my shop mutt helping out with the disassembly.
73 cj5 built 401
Unread 07-17-2014, 09:01 PM   #75
2jeeps1stang
1987 YJ Wrangler
Getting ready to prep the jeep for paint. Painted some accent pieces in satin black. Also finished the step bars and coated with POR. New head lights and LED tail lights should be in this week. Will finish the rear tube fenders and prep the body for paint this weekend. Pics to follow.
73 cj5 built 401
