ive tried every thing !!! - JeepForum.com
post #1 of 47 Old 10-10-2013, 10:49 AM Thread Starter
cody413
I have a 92 wrangler with the 2.5. Im having a problem after it get to normal temp. It'll start and idle fine. But when I get to 4th gear and I'll b coasting and go to hit the gas to maintain speed. (still in 4th) and it will big and jerk like it's gonna stall. I'll have to stop accelerating and then try again and it will clear. Only happens in 4th gear. I've changed TPS, plugs, thermostat housing. Fuel pressure is good. Just had a head job done a month ago. Idk if a 02 sensor can do it. It's Also a manual.
cody413 is offline
post #2 of 47 Old 10-10-2013, 10:54 AM Thread Starter
cody413
I have a 92 wrangler with the 2.5. Im having a problem after it get to normal temp. It'll start and idle fine. But when I get to 4th gear and I'll b coasting and go to hit the gas to maintain speed. (still in 4th) and it will buck and jerk like it's gonna stall. I'll have to stop accelerating and then try again and it will clear. Only happens in 4th gear. I've changed TPS, plugs, thermostat housing. Fuel pressure is good. Just had a head job done a month ago. Idk if a 02 sensor can do it. It's Also a manual. It is also throwing code 22 ( temp thermostat) cause this?
cody413 is offline
post #3 of 47 Old 10-10-2013, 10:58 AM
CrawlingForward
I've definitely heard of cases where a bad O2 sensor can cause issues once warmed up, though I've no personally experienced it.
Try unplugging the O2 sensor first and see if there's any change in the behavior.
The recent head job seems like a red flag, though. Did it start before or after? Why did you need it done?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #4 of 47 Old 10-10-2013, 11:03 AM
Siva283
If your getting code 22 you need to take care of that first. Yes it can cause this issue. Its the sensor in the Thermostat housing. I think its about $30 for a replacment.
Ask me how I know...
Siva283 is offline
post #5 of 47 Old 10-10-2013, 11:04 AM Thread Starter
cody413
It started happening after. But the reason it went it is because I went Mudding more like swapping being a idiot chasing pigs.And it wouldn't start. Mechanic said I warped the cylinder head. It was happening right after the shop but I changed the TPS and ignition coil and cleared up till now.
cody413 is offline
post #6 of 47 Old 10-10-2013, 11:20 AM
Siva283
The ECm is telling you what the problem is or atleast part of the problem. Listen to it. You need to change or atleast test the temp sensor.
Siva283 is offline
post #7 of 47 Old 10-10-2013, 11:43 AM Thread Starter
cody413
Where are the sensors ? I heard there's two.,When I it the head job he put the one by the coolant hose in the front of the engine.
cody413 is offline
post #8 of 47 Old 10-10-2013, 11:49 AM Thread Starter
cody413
I just looked at it. Both are brand new.
cody413 is offline
post #9 of 47 Old 10-10-2013, 02:06 PM
Siva283
They can be bad out of the box. I would hope for that tracing wires is no fun. Check to make sure the connections is tight. Reset the ECM(Dissconnect the battery for 30 seconds. Start it back up and see if the code comes back.
Siva283 is offline
post #10 of 47 Old 10-10-2013, 02:17 PM Thread Starter
cody413
I disconnected the battery for 20 min still on there. Everything I've been reading is sensor related or a fuel pump. Could it be the oxygen sensor
cody413 is offline
post #11 of 47 Old 10-10-2013, 03:51 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I looked at the pistol. It didn't look loaded....
"Your eyes can deceive you. Don't trust them." -Obiwan Kenobi
EDIT: To reset the ECM, simply disconnect the negative battery cable, leaving the positive cable attached, for a period of no less than 10 seconds. Disconnecting the pos and neg terminals may or may not net you a reset depending upon the order in which you reinstall and the speed of re-installation.
The electronic device that was designed to help you diagnose issues with your vehicle is telling you you have a bad temp sensor.
You reset the ECM to clear the code.
It tells you again that the temp sensor is bad.
Must be the O2 sensor.. right?
Test Your Engine Coolant Temperature Sensor:
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #12 of 47 Old 10-10-2013, 03:54 PM
CrawlingForward
To clarify: I suggested unplugging the O2 sensor not because it was most likely, but merely because unplugging it is easy and free and can help you eliminate one possible source very easily.
If you're getting a error, follow that up as the most important.
post #13 of 47 Old 10-10-2013, 04:17 PM
Siva283
OP I am noticing a pattern here that goes along with what I have been telling you. I went through trouble shooting with one of the most qualified people on this forum (Hint: HE designed part of this system for Chrysler) One of the things he taught me is if the computer tells you something listen to it. It is telling you for a reason. You can repeat the code after a reset. THat says bad temp sensor or wiring between it and the ECM.
Siva283 is offline
post #14 of 47 Old 10-10-2013, 04:22 PM
Luuca
Luuca's Avatar
:deadhorse:
EDIT: You may want to follow this other thread on the YJ forums. Looks like the OP has similar issue(s): http://www.jeepforum.com/forum/f12/i...thing-1669905/
YJOTM never
Luuca is offline
post #15 of 47 Old 10-10-2013, 04:26 PM Thread Starter
cody413
I will defiantly have to test the temp sensors. maybe just buy new ones since they are cheap. Which inner should've focus on more. Front or back one ? And if I unplug the 02 sensor and leave it unplugged . How will I know if it's bad ? Will there be no problem with it out ?
cody413 is offline
bucking , stalling
