ive got oil in my air filter!?! - JeepForum.com
post #1 of 14 Old 12-03-2008, 12:08 PM Thread Starter
Kraxen
i recently bought a 92 yj with a 4.0liter and i was checking everything out and when i pulled the air filter there is oil inside the box and on the filter. what could be causing this?!?
92 YJ
95 YJ
Kraxen is offline
post #2 of 14 Old 12-03-2008, 12:11 PM
buzzbrick
That sounds like a PCV issue. They're cheap and easy to install, I'd start there.
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
buzzbrick is offline
post #3 of 14 Old 12-03-2008, 12:17 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Joe Dillard is offline
post #4 of 14 Old 12-03-2008, 12:27 PM
brc94yj
Call up a dealer and tell them you need a CCV kit. Should run you about $25-30.
94 YJ, Red, 4.0, Hardtop, Full doors, 4" RC lift, 31" tires
Red Jeep Club Member #518
brc94yj is offline
post #5 of 14 Old 12-03-2008, 12:31 PM Thread Starter
Kraxen
hey guys thanks, and yeah the pcv seems in bad shape. i hope the engine isnt bad, it has 147k miles on it. its seems to run good just the oil in the filter problem.
92 YJ
95 YJ
Kraxen is offline
post #6 of 14 Old 12-03-2008, 01:13 PM
tuckinauster
tuckinauster's Avatar
Its either an issue with the CCV system, or you have engine blowby. I had the latter I my old 2.5.
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. It’s a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #7 of 14 Old 12-03-2008, 05:38 PM
BlackRhino
BlackRhino's Avatar
I also have blowby in my 2.5. The engine still seems to run well despite spitting out oil.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #8 of 14 Old 12-03-2008, 05:43 PM
yjislander
(insert forrest gump voice) It happens....I had the same thing, the above stated fixed me right up
illigal™
Christian Jeeper #4
92 Yj on 32's
2015 JKU Sahara Hydro blue
yjislander is offline
post #9 of 14 Old 12-03-2008, 05:49 PM
Ironman23
1987 YJ Wrangler
is this post refering to the actually intake filter or the breather filter inside the factory air cleaner housing?
Ironman23 is offline
post #10 of 14 Old 12-03-2008, 05:50 PM
humbert810
Yeah. Sounds like PCV. Once you fix this look up the Oil Scrubber that another jeepforum member posted in the I made _____ for my YJ. It goes in your Crankcase vent tube to celan oil before putting it into the air box to keep the filter dry.
RED 1995 Wrangler YJ DD
Front and Rear custom bumpers
4" RC Susp. Lift
33x12.50x15 Firestone Destination MT's
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
humbert810 is offline
post #11 of 14 Old 12-03-2008, 05:58 PM
Gonewhln
Blow by is also caused by piston rings being blocked or caked up on the rings which causes pressure to blow back out through the valve cover and into the vent tubes going to the air filter.
I had this problem on my 2.5l so instead of rebuilding the engine i bought a new Remanufactured engine with a 3 yr unlimited milage warranty.
Gonewhln is offline
post #12 of 14 Old 12-03-2008, 06:19 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
the 91+ engines don't use a PCV, instead they use a CCV. the only major difference is the first uses an actual valve that's replaceable, the second does not. it's a common problem that's usually easily solved by cleaning the tubes in the system. the sludge will build up in the output line until it plugs it and then the fumes have nowhere to go but back up the fresh air intake line that goes back to the air box taking the oil with it. if cleaning/replacing the lines doesn't do the trick however you may need to take the valve cover off and give the inside a good cleaning. that was the case with mine. my front port was caked with carbon deposits, grease and oil. a little kerosene, a tooth brush and some dental picks too care of things. no more oil in the box even with 160K on the clock.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #13 of 14 Old 12-04-2008, 09:29 PM Thread Starter
Kraxen
thanks guys. i pulled all the hoses and cleaned them and i pulled the valve cover; cleaned that good replaced the gasket and i have to say is the bolt near the fire wall is a pain lol anyways i havnt ran it enough yet to notice any more oil coming out and to top it off i bought a new air filter and the guy didnt have one for a 4.0 yj so i got one for a 4.0 cherokee and its to big. go figure the same motor with different sized air filter >.<
92 YJ
95 YJ
Kraxen is offline
post #14 of 14 Old 12-04-2008, 09:32 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I buy Fram air filters at WalMart for my '91 & '93 YJ's. Fram part number 3363 and it costs about $3-$4 dollars, IIRC.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
synthetic oil filter vs regular oil filter MacK JK Wrangler Technical Forum 2 10-31-2009 11:09 PM
Air Filter Oil Filter whats the difference? LlamaJeep YJ Wrangler Technical Forum 9 03-15-2008 11:52 AM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 05:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 10:02 PM
stock filter vs. K&N air filter 90yjwrangler YJ Wrangler Technical Forum 8 12-01-2004 06:49 PM
