#16 | ||
OK so waht does $40 each Canadian translate to in US? And that is for a set of 2 front and 2 back right?
For sale 1992 YJ Wrangler: Hurculiner, bestop Safari top.RC 4" lift 32 AT wheels, custom bumpers, 2000 Corvette Roadster: Almost stock http://www.demonoff-road.com/ 2002 Avalanche: To many mods to list |
#17 | |
JF Administrator, eh?
Attached is my AutoCAD drawing that I use at work that is imported to our laser for cutting. You will see that I am working on another shackle-style that I wanna test out as well. What the price works out to is $10 Cad per piece of steel. You will require 4 for the front and 4 for the back. I have 32 of the straight shackles and 8 of the boomer shackles made right now that I can ship out. The steel is "unfinished" - not painted, galvanized, or protected in anyway. I'll hit them with a wire-brush to clean any burrs off, and polish the bolt-holes so that a stock bolt will fit very tight (I made the holes undersized so that there will be no slop once mounted). Let me know if this works for you.
Hello, my name is Vance and I am a Jeepaholic. Its better to be naked with your friends, than to be clothed with your enemies #1 From street to trail, '88 YJ on 38" tires does it all well #2 Silver 2006 TJ Unlimited, zombie ready as the daily-driver .. and now a Kawasaki KLR650 DualSport bike TEOTWAWKI |
#18 |
Just call me Moose
^^ Do they provide any lift? I have a pair of Currie greaseable shackles already that I believe are 5/8" lift.
#19 |
The standard is (XXX"/2) = added height. The 4" (as shown above) is the stock distance between bolt-holes, add in the added height of 2" and you have 6" between holes for a 1" overall extension.
There are differences in quality of springs and such which can influence the real amount of lift, but it should be close to that. There are no guarantee's when you modify a Jeep. ![]()
#20 |
I figure that I might as well update the changes to the Jeep since this was last updated.
Cragar V5 rims Decals ![]() Slip Yoke Eliminator - SYE ![]() ![]() Stinger
#21 |
Looking good!
Need to clean up that windshield frame before you end up needing a new one! In the top pic, are those TJ soft uppers? If so, how do you they fit (what is needed to make them work with the YJ lower door?) Cheers! ~K |
#22 | |
Good eye. The uppers are TJ-uppers with the middle post cut-off, the front post fits just right (remove paint and then sand-down to fit into the YJ pin-holders) and then the back post has to be cut-off and welded back into place with someone holding the window tight against the hard-top. It also needs the paint removed to fit into the YJ-pin-holders that are in the door. If you are welding inside the Jeep (like I did) have some replacement pin-holders on-hand .. they kinda melt away from the heat .. ![]()
#23 |
#24 |
Junior Member
Well my Jeep has had some more modifications since the last time I updated this. Thanks to my other half I now have a stinger on the front. See picture below:
I've had some other work done too. I had my front grill and fenders painted with Rocker Guard. We left the headlight frames white and I gotta see I like the contrast. Yesterday we took turns erasing the black YJ lines off the hood. The plan is once we clean up the area where the lines were my Wildmist purple name in flames will be replacing the lines. More pictures to come once the weather clears. Kudos to NaeKid for spending his time helping me make my YJ slowly into the machine I want. ![]()
Mostly stock 1989 White Jeep YJ. 31" Goodyear Wrangler AT/S 2" Body Lift White Jeep Club Member 181 And a boyfriend named NaeKid. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
