Its comin along SLOWLY... - JeepForum.com
post #1 of 3 Old 10-07-2003, 03:24 PM Thread Starter
Stock88YJ
Stock88YJ's Avatar
Im makin myself get on it hard and work to get my Jeep back on the road. Here is some pics. A few from before and a few of what i have done.(excuse the junk lying around just moved and my Jeep makes a perfect leaner for the ping pong table.
Before:
So Far:
What do you think so far? I think im gonna add a 2 inch body to it b/c i want a little more room above the tire.
Trent
88 YJ with a 4.2 I6. Hurculined, CD, CB, flowmaster. 4" Skyjacker suspention lift with revolver shackles, SYE, 33x12.50 explorer pro comp all-terrains!
White Jeep Club Member #16
97 Ford Ranger 2.3Turbo megasquirted...
Stock88YJ is offline
post #2 of 3 Old 10-07-2003, 05:22 PM
Moxley
Moxley's Avatar
2017 JK Wrangler
Trent,
Looks like you've put a lot of work into it! Better hurry up though, next month it's going to be getting too cold to bust your knuckles on stuff. Seems like you have good clearance now, so you may wish to consider going with only a 1" BL. The 1" kit is much easier to deal with when it comes to adjusting linkage, etc.. Keep up the great work...
Doug
Moxley is offline
post #3 of 3 Old 10-07-2003, 09:15 PM
RideRed04
RideRed04's Avatar
Aren't before and after pics fun? Check this bad boy out! Its been a long, bloody path, but its been worth it.
before (rescued from an old man, where it served RV duty)
Little over a year later, babied and used like a Jeep should be
2000 WJ Limited 4.7 QD
RideRed04 is offline
Wire comin from under seat??? Wrangler_91 TJ Wrangler Technical Forum 4 05-09-2009 10:59 PM
Knockin Comin from Front of motor MercuryTec TJ Wrangler Technical Forum 13 04-13-2008 09:24 AM
why is there water comin from under my dash? Git-R-Done YJ Wrangler Technical Forum 15 11-30-2006 09:38 PM
Hey all, comin up on 75K, timing belt replacement? cygnus3978 TJ Wrangler Technical Forum 3 11-03-2005 10:09 AM
Bad KNOCK comin out of 4wd JakeJones TJ Wrangler Technical Forum 7 12-07-2004 01:58 PM
