Items on firewall, Unknown what they are - JeepForum.com
post #1 of 11 Old 08-31-2011, 09:32 AM Thread Starter
pfohljerry
I can't figure out how to attach photos from my hard drive (I'm on a Mac). so I'll do my best to explain. This is an 89 yj with a 4.2 (m).
On the firewall, passanger side there are 2 white plastic items that has a place for a vacuume line (mine only has 1 line attached. it goes over to a tree just above the valve cover).
attached to that tree is 3 items joined together by vacuume lines and each has an electronic connection.
Can you tell me what these are and there purpose.
Jerry "PopIrish" Pfohl
pfohljerry is offline
post #2 of 11 Old 08-31-2011, 09:43 AM
dancytron
Sounds like the vacuum sensors from your description, ( http://home.sprynet.com/~dale02/vacuum.htm ) but hard to tell without a picture. Look at the link for answer.
http://home.sprynet.com/~dale02/list.htm
dancytron is offline
post #3 of 11 Old 08-31-2011, 09:51 AM
timatoe
timatoe's Avatar
The answer to the vac question is above, see the sprynet links.
As for pics, do this.....
http://www.jeepforum.com/forum/f29/h...pforum-574312/
timatoe is offline
post #4 of 11 Old 08-31-2011, 10:11 AM Thread Starter
pfohljerry
Thanks for the info on the photo. lease check it out. I think we are on the same page....What is it's purpose?
My green side has no vaccume line attached...Should and if so where is it attached
Last edited by pfohljerry; 08-31-2011 at 10:20 AM. Reason: Added photo and question
post #5 of 11 Old 08-31-2011, 10:17 AM
dancytron
They sense vacuum and feed that information to the computer. The link explains it.
post #6 of 11 Old 08-31-2011, 12:54 PM Thread Starter
pfohljerry
Thank you....
post #7 of 11 Old 08-31-2011, 01:31 PM Thread Starter
pfohljerry
Where does the green 4" vacuume line hook to? As you can see mine is not hooked to anything.
post #8 of 11 Old 08-31-2011, 01:50 PM
Old4X
1990 CJ7
Both vac switches hook to manifold vacuum. You can run one line and a "T" and hook them both to it.
The other 3 switches are for the pulse-air system.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 11 Old 08-31-2011, 03:43 PM
mcmud
1983 CJ8
It appears to me that neither of them are connected to a vacuum source.
With the YJ, the 4" switch connects to the 'E' ported nipple (left front on the BBD) and the 10" (green top) switch to manifold vacuum.
You may notice that with the CJ layout (on the sprynet site) the 'S' ported nipple is used instead...stick with the 'E'.
This may help to sort out any other tube routing.
mcmud is offline
post #10 of 11 Old 08-31-2011, 08:56 PM
timatoe
timatoe's Avatar
It's quite possible that the ECU is no longer used, as in the Nutter Bypass may have been done previously, which case those do nothing.
timatoe is offline
post #11 of 11 Old 08-31-2011, 09:42 PM
Old4X
1990 CJ7
Every time I look at that diagram I get cross-eyed. You are right, as usual.
Old4X is offline
TF 999 unknown fluid, what to add? drespecki YJ Wrangler Technical Forum 12 12-30-2013 10:17 PM
Where Can I Get These OEM Items? Pikes_Peak_Trailers TJ Wrangler Technical Forum 6 04-05-2011 03:29 PM
New JK items Raingler JK Wrangler Technical Forum 12 07-25-2009 09:11 AM
Unknown Part Coyne09 TJ Wrangler Technical Forum 3 10-22-2008 03:15 PM
yj unknown locker teejmcd YJ Wrangler Technical Forum 9 08-17-2008 08:56 AM
