Isuzu dana 44 swap qustions. - JeepForum.com
post #1 of 12 Old 09-05-2011, 12:20 PM Thread Starter
deathtrap
I want to swap in a isuzu D44 in place of my 35. I need to keep my 5 on 4.5
wheels. has anyone redriled the 6 lug isuzu axles and rotors to fit stock wheels? It looks like the smaller bolt circle will be into the large center hole.
I know most people that do this swap run 6 lug waggy stuff in front.
Also I hear that the dana 35 yoke can be swaped to replace the oddball isuzu
drive flange, Anyone know If its true? If someone has pics of how thay did
the parking brake would be cool. None of the info I find adress these issues.
Thanks.
deathtrap is offline
post #2 of 12 Old 09-05-2011, 03:17 PM
Nickabis
Just a thought, have you looked into the ford 8.8 explorer swap? It's a 5x4.5 bolt pattern so no re-drilling required. the newer explorers come with disk brakes. I cant remember the years. And you don't need to change the front.
Nickabis is offline
post #3 of 12 Old 09-05-2011, 03:26 PM
I8AHUMR
x50000000
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #4 of 12 Old 09-05-2011, 03:33 PM
TheNewbie
I think it was 96 and newer with the disc brakes.
The width abotu the same as the D35 in your YJ bow, and it's comprible to a D44.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 12 Old 09-05-2011, 04:46 PM Thread Starter
deathtrap
Thanks guys, but I think pretty well set on a d44 of some kind.
post #6 of 12 Old 09-05-2011, 05:28 PM
Nickabis
That is understandable, it's your jeep. I only mentioned the 8.8 because it would cut down the work that you want to do with the d44, it's a pretty straight forward swap, very comparable to the 44, and they are very common, well around my area at least. Good luck with the swap, sorry I wasn't more help with your initial question.
Nickabis is offline
post #7 of 12 Old 09-05-2011, 05:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
How about contacting superior and getting some chromoly shafts with the right bolt pattern?
Luck Favours The Prepared
Anticanman is offline
post #8 of 12 Old 09-05-2011, 06:00 PM
93jeepyj
Do you already have the isuzu 44? I was able to find an MJ 44 and the only thing I had to do was weld on spring perches and shock mounts. brakes and parking brake hooked up the same, yoke was the same size, bolt pattern was the same. ect. Took a little digging to find but xj and mj 44s are out there, theres also tj and lj 44s but there probably priced a bit higher.
93jeepyj is offline
post #9 of 12 Old 09-05-2011, 06:34 PM Thread Starter
deathtrap
I havent got one yet, the xj/mj 44s go pretty fast in the yards while the isuzus get ignored. thay all seem to
have good gears 4.10 or 4.56. The good 8.8s dont stay long ether. custom axel shafts are an option but was
wondering if anyone has redrilled the stock isuzu shafts to save some coin.
post #10 of 12 Old 09-05-2011, 06:40 PM
notmyj
Its also worth mentioning that the 8.8 is stronger than the D44. If your trying to be different, then by all means do as you wish. But if your looking for the best bang for the buck, then the 8.8 is the way to go. Also, if your having trouble finding a suitable axle, no matter which one it is, look at www.car-part.com.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #11 of 12 Old 09-05-2011, 06:54 PM Thread Starter
deathtrap
Im not tying to be diffrent. I just think getting a good rear axle with 4.56 gears allready in it at junk yard prices
is a plus. It seems like a good swap aside from getting the wheels bolted on safely. thanks guys.
post #12 of 12 Old 09-05-2011, 07:52 PM
TSEJEEPERS
PM Vlucdog in the CJ forums.
He is running a Isuzu rear end in one of his CJs.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
Honda And Isuzu Dana 44 Swap In A Tj mudslingertj24 TJ Wrangler Technical Forum 6 08-15-2011 10:04 PM
Qustions about a top jwnewell001 YJ Wrangler Technical Forum 4 08-18-2010 04:05 PM
Isuzu Dana 44 2wd vs 4wd differences Cajun90YJ YJ Wrangler Technical Forum 1 05-03-2010 07:12 AM
Isuzu Dana 44 owners walkin YJ Wrangler Technical Forum 1 04-04-2010 01:59 PM
Isuzu D44 swap...questions Spinny YJ Wrangler Technical Forum 1 08-30-2007 09:10 PM
