Issues with '78 F150 Front D44 (looking for new axles) - Page 2 - JeepForum.com
post #16 of 16 Old 08-15-2010, 08:17 PM
jsawduste
2006 YJ Wrangler
Good response Jon. Glad you found Mr. N`s information. Very informative and current.
From experience in re-tubing. 3 HP Dana 60`s in the last couple years. It is a nasty pain in the butt job that requires tools most folks do not have.
Hold out for an F250 HP44 that has ll the tube you might want. Narrow it to whatever width you are looking for.
You know another consideration.......Several companies (including Dana) sell just the bare housing at a pretty reasonable cost. That way you could build your axle with whatever tube length/thickness you want. Not have to screw around trying to retube or narrow a full width axle.
DTS in Michigan, Solid, Rockcrusher, Tera are a few that come to mind for center sections.
Inner C`s and knuckles can be had for cheap and you could choose between Chevy of Ford outters.
As much as I like the Ford 9 inch you are faced with two issues. Both can be overcome but why ?
1. The pinion height on the 9 inch is very low. Meaning your DS angle will be severe.
2. The typical 9 inch housing is not very strong. Bent tubes are a real possibility without a top and rear truss. Now the trusses get in the way of the gas tank. Much better to use an aftermarket housing that is designed for off road usage.
For kicks here is a chart on pinion height and DS lengths for comparison.
True Hi9 - Driveshaft Comparison pinion height hi high ford inch 9 nine
I like the 8.8 with Moser 7750DB ends. Allows for bigger/better bearings. Gets rid on the C-clip and still allows all your disc brake/parking brake stuff for a nice clean install. Consider an LPW girdle to stiffen the whole center section and reduce gear deflection.
LPW Racing Products, Aftermarket Parts, Automotive Accessories, Muscle Car, Automotive Components, Hush Performance Components, High Performance, High Performance Parts, Rear End Girdle, Rear End Brace, Differential Girdle, Differential Cover, Differ
jsawduste is offline
9" , axles , d44 , ford , swap
75-77 F150 Dana 44 front axle question 93YJfalcon YJ Wrangler Technical Forum 21 02-14-2013 02:07 PM
'79 F150 Dana 44 High Pinion Front End schecterguy YJ Wrangler Technical Forum 14 06-07-2009 09:49 PM
77-79 ford f150 axles spring location on yj cerial0411 YJ Wrangler Technical Forum 6 11-27-2008 08:37 AM
1989 F150 Axles under a 2004 Jeep TJ? JFiorentino TJ Wrangler Technical Forum 15 05-29-2007 02:48 PM
What axles? 78 F150 4x4 jeepjared84 YJ Wrangler Technical Forum 13 04-22-2007 06:59 PM
