Issues with '78 F150 Front D44 (looking for new axles) - JeepForum.com
post #1 of 16 Old 08-14-2010, 09:00 AM Thread Starter
chupacabrah
chupacabrah's Avatar
Hey guys,
The other weekend I tore up my dana 30 (ball joints ripped out, snapped axle, tore hub CV ears...etc). (the story, pictures, and video of that can be found here)
before this breakage I had broken my center shaft < 1 month earlier. actually I replaced this with my spare the day before this, haha :-/
So, I think it is time to upgrade, and go SOA all in the process. my goal is to run no larger than 38" tires
I found a guys with a '78 Ford F150-- front D44 rear 9". this would be a good set, however I think it has the dreaded cast radius arm wedges. I am pretty confident I could get the pair for $300 (maybe a little less).
How big of a deal is it to work around this? Is it something to completely avoid?
What would the solution be? cut out the wedge section and re-sleeve or something like that?
Or is it best to just keep looking? Time is not really an issue, my jeep is up on stands, and I can let it sit for as long as I need to--although I'd rather have it up and running sooner, I want to make sure the SOA is done right so I will progress as time and funds allow.
I really only NEED a front axle, as I have an 8.8 rear, but if I can get a 9" or something stronger then I could sell my 8.8--however then I would be limited as far as axle width and bolt pattern. What other options should I look for?
It seems like it is hard to find anything decent that isn't way overpriced.
Thanks
Here are some links for information (for my and others' reference):
http://www.jeepforum.com/forum/f11/b...a-44-a-747194/
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #2 of 16 Old 08-14-2010, 10:31 AM
cowboy63b
hack off the radius arm crap and runn the 9 and 44, just my .02
Violence-it may not be the anwser, but it sure cuts down on the questions.
cowboy63b is offline
post #3 of 16 Old 08-14-2010, 11:01 AM
levergun
1979 CJ5
I would keep the 8.8. The 9" isn't worth it. Cast perches are impossible to work with. Possible just more trouble than you would want.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #4 of 16 Old 08-14-2010, 11:39 AM Thread Starter
chupacabrah
Yeah that's what I am worried about. Being that whole radius arm wedge piece is cast there isn't really a way to just hack it off.
How impossible?
I was thinking maybe I could cut the tube and re sleeve it with DOM (like joe dillard did with his d30 in his write up)
But yeah....it could definitely wind up being more trouble than it is worth
-Jon
post #5 of 16 Old 08-14-2010, 11:46 AM
cowboy63b
plasma cutter, or hack off what you dont need, and build your own brackets for a cool SOA, or even better, go find a ford D60(solid, not the TTB crap), and corp. 14B and re center the perches to your width, and run 1 tons!
post #6 of 16 Old 08-14-2010, 01:12 PM
fratis
fratis's Avatar
i think people are missing the point of your post. you really have to look at the axle assembly. dont discount it until so. people will spout off about what year assembly has what but its really moot as there was some leeway year to year. all radius mounts from any year are "cast" steel. the difference is one is a single unit that the tubes are pressed into; the other is made up of two pieces that are welded onto either sides of the tubing. it is real easy to tell the difference even before pulling the unit from the vehicle. ive found a 78 with the more desirable two piece design even though people will argue that 77 was the last year.
you will need to cut the assebly down as it will be way too wide for the 8.8. a couple inches are fine but you are looking at a difference of 8." also if you are using the factory 4 on 4.5 pattern you will need to change that. this is where the previous doesnt make sense.
the matching 9" would come in handy. matching gears, width, and pattern. the 8.8 is fine for the dana 30 crowd but makes for allot of work for those looking for a front axle replacement as well.
fratis is offline
post #7 of 16 Old 08-14-2010, 02:08 PM Thread Starter
chupacabrah
I will have to go back out to verify if it is the two pc or one pc. If it is the one pc should I totally avoid it?
If I do get it I will keep it full width and run it with the 9"--i'd have to regear and weld up new perches and stuff regardless of axle since I will be doing soa.
9" is stronger anyway right? Even tho it is lp and has drum brakes.
-Jon
post #8 of 16 Old 08-14-2010, 09:04 PM
Provojeep
I just put a D44/9" from a 76 F-150 SOA under my jeep. The axles are 5" wider than my stock axles so my wheels stick out a bit more. I strongly suspect that your D44 has the two piece axle tubes and that they will need to be either re-tubed or sleeved and that will cost you a bit of cash. As for mixing the D44 and the 8.8 there would be a significant width difference between front and rear and, as mentioned, the D44 and 9" are 5 on 5.5 bolt pattern while your D30 and 8.8 are 5 on 4.5.
I am very happy with the combination on my jeep. You can get alloy axles shafts for the D44 and the ring and pinion will be stronger than you current D30. The drum brakes on the 9" were not an issue for me. If you can get around the two piece axle tubes then go for it, but do the SOA right and don't cut corners.
Good luck.
93 YJ, 4.0L, AX15 with 90 frame. D44/9" on 35" MTR's.
Provojeep is offline
post #9 of 16 Old 08-14-2010, 09:27 PM
parkerm26
i would say ditch it. i tried this with a bronco D44 but i just got so fed up with modifying it so much that i scrapped it. go to 1 tons. 78-79 f350 (some 250's) have the right pumpkin placement up front and you wont second guess 40's on those, especially with a 200 hp engine. just gear it right and it will be better in the long run
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #10 of 16 Old 08-15-2010, 05:40 AM Thread Starter
chupacabrah
I guess I'm not seeing why this would be a big hassle or expensive..could you please explain?
Could I just just cut it off, get some DOM, and do something like this? http://www.jeepforum.com/forum/f12/h...beware-793813/
Seems like that would work, but I don't know. I will see if I can go back out there and check if it has the single cast mold or the welded on wedge. If it is the cast piece I will probably just avoid it and keep looking, unless someone says the above is a viable option
I think I am going to tear down my jeep today and start posting stuff up for sale that I am not going to need
-Jon
post #11 of 16 Old 08-15-2010, 06:58 AM
Cajun90YJ
Why not just leave the radius arm pads on the axle and weld on your your spring pads. I'm not sure if the radius arm pads would interfear with your spring pads? Just an idea and I am not sure if it would even work.
I just pulled front and rear axles out of a 8/77 ford f -150 which should be a 78 and it was the 1 peice axle with weld on radius arm pads so check yours to be sure.
Cajun90YJ is offline
post #12 of 16 Old 08-15-2010, 03:58 PM Thread Starter
chupacabrah
I just checked it earlier today. it is the type with the large cast for the radius arm wedges. makes it pretty much unusable short of re-tubing the thing. Which isn't really bad, so I may come back and do that later if I can't find some other option.
but something is bound to turn up!
thanks for the info, everyone.
-Jon
post #13 of 16 Old 08-15-2010, 04:53 PM
Provojeep
Yep. You just need to find the DOM to sleeve the existing tube or to replace the entire tube. DOM is not cheap but if you can weld it is not a difficult fix.
post #14 of 16 Old 08-15-2010, 06:47 PM
jsawduste
2006 YJ Wrangler
Read this, it is the bible of the Dana 44
Mr.N's Dana Articles to Include 44, 60 information.
The vast majority of responses here are from folks who really do not know what they are talking about.
After you read these article you will be informed enough to make a wise decision.
jsawduste is offline
post #15 of 16 Old 08-15-2010, 07:27 PM Thread Starter
chupacabrah
Yep, I read that site, that's how I actually found out lots of detail on what to look for on these axles I was looking at.
I wouldn't be scared to re tube it, but then I just really don't think it would be worth it. the 9" is LP, and isn't THAT much greater than the 8.8 I already have (esp if I wind up with a super88 kit).
and the d44 isn't THAT much better than a d30, esp once a d30 has chromo shafts.
So...I am thinking that I may just stick with what i have (d30/8.8) and get the chromo stuff for those and limit my tire size to 35s. in the meantime I will keep my eye out for some d60/70s which I'll jump at if they aren't ridiculously expensive.
bigger would be better, but also more expensive...and time consuming. I don't DD my jeep, so it probably *should* be bigger by now, but I don't get to go wheeling as much as I used to (or have as much free time or money!).
actually I did have a guy around here who wanted to trade a d60/70u (35 spline shafts and all that) for my axles + $800 cash, but his front axle his psd so then I would have to find a dana 300, and...and...and etc.
-Jon
9" , axles , d44 , ford , swap
75-77 F150 Dana 44 front axle question 93YJfalcon YJ Wrangler Technical Forum 21 02-14-2013 02:07 PM
'79 F150 Dana 44 High Pinion Front End schecterguy YJ Wrangler Technical Forum 14 06-07-2009 09:49 PM
77-79 ford f150 axles spring location on yj cerial0411 YJ Wrangler Technical Forum 6 11-27-2008 08:37 AM
1989 F150 Axles under a 2004 Jeep TJ? JFiorentino TJ Wrangler Technical Forum 15 05-29-2007 02:48 PM
What axles? 78 F150 4x4 jeepjared84 YJ Wrangler Technical Forum 13 04-22-2007 06:59 PM
