Issues with 4cyl. - JeepForum.com
post #1 of 4 Old 05-16-2012, 08:54 AM Thread Starter
4kidsxj
Issues with 4cyl.
This little YJ is receiving way to much gas or maybe it has more than what the eye can read, the 4cyl. has gas mixed in with oil. With little mechanical knowledge, way to much gas is going in the combustion chambers and not enough is getting burnt! We(In-laws and I) thought the O2 sensor was bad, so I replaced it last night. Before replacing the O2 sensor, the jeep ran real crappy, it had a low idle and when it would pick up it sound like an old John Deere tractor....
4kidsxj is offline
post #2 of 4 Old 05-16-2012, 09:13 AM
Xpress
Check all of your vacuum lines, replace them if they're more than a few years old (all of them). Check your MAP sensor as well, ontop of that make sure there's no exhaust leaks before the cat, because it can throw everything off and cause your computer to think its running lean, thus dumping more gas into the intake. Replace all of your spark plugs, plug wires, distributor, rotor, even things like changing air filters and fuel filters can help.
Basically, do a full tuneup. These are high maintenance vehicles, they like to be loved.
All about that unibody life.
Xpress is offline
post #3 of 4 Old 05-16-2012, 09:31 AM
Que89YJ
When you replace any sensor you need to do a battery disconnect to clear the computer calibration and fault codes. Disconnect it for a long 10 count. It seems like your post was cut off. How is it running now?
Check for codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #4 of 4 Old 05-22-2012, 05:05 PM Thread Starter
4kidsxj
The darn jeep won't start now! I changed the spark plugs, waiting to replace the spark plug wires and inspect the cap & rotor, maybe the map sensor needs replaced also
4kidsxj is offline
