Israeli AIL Storm grille restoration - Page 2 - JeepForum.com
 1Likes
post #16 of 29 Old 02-23-2013, 12:01 PM
crackedcornish
are those lenses DOT approved?
here something different like that goes under the magnifying glass at the inspection station
would hate to see you go through the work, only to be turned down at inspection time by some overzealous DMV worker because of something trivial
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #17 of 29 Old 02-23-2013, 06:46 PM Thread Starter
shnitzle
thanks for the wiring diagram.
and I am going to try to to make the remote hood release.
first i gotta replace the small plastic mounting tabs for the headlights 3 broke during shipping, and i have to figure out how to fix the bezel.
the holes look to be in the same place as any other yj grille.
here are some more pictures
thanks for all your help
shnitzle is offline
post #18 of 29 Old 02-23-2013, 06:51 PM
Old4X
1990 CJ7
That bezel looks just like the one on my 78 C10 pickup.
If not, you should be able to put it back together with some fiberglass and resin.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #19 of 29 Old 02-23-2013, 08:23 PM
crackedcornish
http://www.urethanesupply.com/Plasti...Fix-Kit-Black/
http://www.urethanesupply.com/PlastiFix-Grille-Repair/
post #20 of 29 Old 02-23-2013, 11:09 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
How can I repair/replace the bezels?
You may have some luck with a plastic welding kit from Harbor Freight or the like. Make the repair then spray paint them. That is such a neat grille, I'm sure you will find a way to make it work. If not, put me in line for the impending auction.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #21 of 29 Old 02-25-2013, 04:35 PM
jeep63
YJ Collector
jeep63's Avatar
That is one cool looking grill; I am subscribing to this for sure.
good luck with the restore/install.
jeep63 is offline
post #22 of 29 Old 02-25-2013, 05:31 PM
NHfireLJ
NHfireLJ's Avatar
Watching......and waiting
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #23 of 29 Old 03-28-2013, 01:07 PM
Prspallone
1982 CJ7
Any updates?
Prspallone is offline
post #24 of 29 Old 03-28-2013, 07:23 PM
plym49
Hey Brooklyn:
1 Repair the cracked bezels with black MarineTex. JBWeld on steroids. Just a little at a time, and use a Dremel and sandpaper to shape it. The MarineTex will fill the gaps and add strength. Then, you can use a little Bondo or glazing putty to mint them out. Prime and paint.
2 While I do not know anything about that grille, and H4 is an H4 so you should be able to splice on the connectors you need. I agree that you should wire the headlights thru relays.
3. Use the regular old Jeep external hood latches. You don't need anything else IF you have good-quality ones and they are installed properly.
4 Your Jeep looks fantastic with that camo paint job and it will look even better with the Israeli grill.
plym49 is offline
post #25 of 29 Old 03-28-2013, 10:11 PM Thread Starter
shnitzle
thanks for all the help
its taking a while because im replacing the engine in the jeep and its a slow process between work and school and the fact that im doing it in a relatives driveway not that close to my my house.
im going to try making the bezels on inventor and print them out in school.
Ill use the latches until i get around to installing an hood release inside the cab. what car can i get that out of?
ill post any updates
thanks again
shnitzle is offline
post #26 of 29 Old 11-27-2016, 02:36 PM Thread Starter
shnitzle
Gave up, check it out on ebay
http://r.ebay.com/89aw2d
shnitzle is offline
post #27 of 29 Old 11-27-2016, 02:46 PM
NHfireLJ
NHfireLJ's Avatar
That sucks
SOLD
YJOTM FEB 2013
post #28 of 29 Old 11-27-2016, 10:18 PM
calpbs
That grill is as cool as cornbread. Southern saying.
I have done so much with so little for so long, I can do anything with nothing forever.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #29 of 29 Old 11-28-2016, 11:55 PM
bruinjeeper
bruinjeeper's Avatar
Why did you give it up?
What are the real dilemma's here? Just the connection for the lighting? The dimensions and logistics can't be all that different from the YJ clip.
That thing is hella cool
calpbs likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is online now
grille , headlight upgrade , headlights , military jeep , wiring
