Internal vs. External Clutch Slave - JeepForum.com
post #1 of 3 Old 03-30-2004, 10:55 AM Thread Starter
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
From what I hear, the external clutch slave is much less labor intensive to replace when (not IF from what I hear) it goes.
My question is other than the difficulty of replacing the slave, is there any difference between the reliability between internal and external?? Does one fail more ofter than the other?
I can probably get a smokin' deal on a beat '91 XJ with 4.0L HO, AX-15, and NP-231 to use at least for its trans/t-case to replace my BA-10/5 / NP-207... Would it be possible to pick up anything from a j-yard to convert this '91 AX-15 to the later '94+ external slave??
Thanks for any input.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #2 of 3 Old 03-30-2004, 10:10 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
as far as reliabilty, I don't think one is better then the other. only thing is, if the new slave is bad when you put it in there, the tranny needs to come back off again. not too bad really, just HIGHLY annoying. No doubt the external is the better way to go. I have heard of people doing a conversion on the older trannys to allow for an external slave, but I don't know the specs off hand myself. you might search Pirate for it, I'm pretty sure that's where I read about it. If i remember right, you need the fork from an external model, the new slave and you may have needed to fab your own support for something. I'm not sure. Sorry I can't be more specific.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #3 of 3 Old 03-30-2004, 10:23 PM
GreenReaper93
GreenReaper93's Avatar
I tried to do the conversion with my '93 YJ. My only reason for failure is that I couldn't find all the parts in time. You'll need the bellhousing from a '94+ AX-15, the throwout bearing, the pivot cup, the throwout fork, return spring, and the external slave from what I remember. There's no real need to fab a support for the External Slave (unless you want to try and beef it up for an extreme case - can't see how, but anything's possible). External is much better. Parts can be hard to find at times for the swap, but if you have a line on parts I'd do it! Good Luck!
GreenReaper93 is offline
AX-15 Internal to External Slave Cylinder Clutch line write up bigredcherokee YJ Wrangler Technical Forum 40 11-15-2014 03:10 PM
Internal or external slave? XsaltlifeX YJ Wrangler Technical Forum 2 09-23-2009 07:15 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 10:26 AM
Internal or External Slave Cyl 73Dart YJ Wrangler Technical Forum 6 04-15-2009 09:57 PM
Internal or external slave? Sawbladz TJ Wrangler Technical Forum 3 05-14-2007 11:15 AM
