Internal Slave Cylinder Quick Disconnect - JeepForum.com
post #1 of 13 Old 04-18-2009, 08:51 PM Thread Starter
Cruisers
Cruisers's Avatar
I bought the clutch master cylinder adapter and steel braided line from Advance Adapters. Underneath at the slave cylinder, I have taken off the quick disconnect from the metal line coming off the slave cylinder. It is a male end. The new steel braided line is a male end. I used an inverted flare line coupler to connect them, bypassing the quick disconnect althogether. Luckily, the bleeder screw worked and I successfully bled the lines. After about a three mile drive and some shifts, it appears that so far I have no leaks and my clutch works fine.
QUESTIONS: Is this a long term solution? Am I going to blow out my internal slave cylinder? What was the purpose of the quick disconnect? What am I missing here, if anything?
Cruisers is offline
post #2 of 13 Old 04-18-2009, 10:17 PM
Opihi59
from here it gets rough
Opihi59's Avatar
The quick disconnect was the technique utilized to connect the line from the master to the slave cyl. I had my pop loose on me a few times, completely lost faith in it and the internal slave so I converted to external slave.
If your fab doesn't fail or leak, it sounds like a permanent enough solution.
Regarding the blow out question for the internal slave cylinder--I seem to understand you have replaced your clutch master cyl (?). The general finding on replacing one component of the clutch hydraulics is that likely the other component will soon fail. If you are running a new clutch master, I would be willing to bet your clutch slave cyl will be soon to take a dump.
It is a simple enough process to replace your internal slave with an external slave. You just gotta round up parts first, and of course it is the opportunity to put in a new clutch as part of the process. Planny writeups on here if you choose to do this. I did it on my 93 and I'm real happy I did.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 13 Old 04-19-2009, 08:46 AM Thread Starter
Cruisers
Cruisers's Avatar
Good Advice
That's good advice about changing out the slave cylinder, and doing the clutch while I'm in there. I've looked at the sticky on this and it looks like a project in my very near future.
In the meantime, I'm still wondering what the purpose of the quick disconnect is other than just functioning as a quick disconnect? Why is it designed as it is? I can find no info on this part. Anyone have any ideas?
Cruisers is offline
post #4 of 13 Old 04-19-2009, 10:51 AM
Burnerman
Burnerman's Avatar
I dunno about why they used it but... How much was that kit from Advance Adapters? Why just had to deal with that quick connect in my sons YJ and it looks like it's weeping. It's the plastic line and I've heard it's dealer only and around $75. We just did the clutch and slave so the external is out for now. Just wondering what's the cheapest way to fix it.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 13 Old 04-19-2009, 04:58 PM Thread Starter
Cruisers
Cruisers's Avatar
Advance Adapters Solution
I had read your previous posts. I don't understand why Advance Adapters made their steel line hose with the adapter that they did. I will call them Monday. But why leave us with two male ends to put together and not even suggest an inverted flare coupling? Even better, why not design the proper end to go into the quick disconnect? It doesn't look like it would be that hard for a design shop such as theirs. I mean after all, they designed an adapter for the other end, the clutch master cylinder end!
I KNOW I need to drop the tranny and replace the internal slave cylinder with an external one, and I will do that, but in the meantime I'd like to drive my Jeep. I just don't want to damage it in some way (or leave myself stranded) by using this flare coupling/ bypassing that quick disconnect if it performs some vital function, such as regulating the fluid pressure or something like that.
Also, if your setup is weeping I'll bet that mine will start that too once I start four wheeling. What a hassle, and it all started when I cur that stupid plastic line off the barbed fitting on the old clutch master cylinder. I was STUPID for not reading all the advice on JeepForum FIRST!
So, I paid for a subscription here. I know it will pay for itself in the advice I get.
By the way, I have $77 paid to Advance Adapters, including shipping to Indiana. Then I have $3.47 in an inverted flare coupling plus gas to drive the 47 mile round trip to the only place open that had one on a Saturday afternoon in rural Indiana.
Sigh.
Cruisers is offline
post #6 of 13 Old 04-19-2009, 05:03 PM
Burnerman
Burnerman's Avatar
Ok.. I guess I'll stop by the dealer and see what their real price is for the stock replacement. In hindsight I guess we shoulda done more research and swapped to and external slave... Oh Well.. live and learn...
96 ZJ.
post #7 of 13 Old 04-20-2009, 06:10 AM
wendell
1987 YJ Wrangler
Bernerman, I've seen your jeep on many post and it allways catches my eye. You have a very sharp YJ!!!!!
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #8 of 13 Old 04-23-2009, 04:14 PM
Burnerman
Burnerman's Avatar
Thanks Wendell. I took my sons ZJ to the dealer to get 2 free rotors, a new free cat, an ECM flash and a new shifter lockout. Open recalls are pretty cool. Anyway I asked the parts guy how much the clutch line from the master to slave was... $180!!!! This is just the plastic line with that stupid quick disconnect on the end. He said he could make me a deal and sell it for $160.. That's nuts. If Burnerboy's leaks we're gonna be fabbing stuff up.
96 ZJ.
post #9 of 13 Old 08-27-2013, 10:09 AM
davebl260
Slave quick disconnect
My question is, how did you get the quick disconnect off of the new slave cylinder?
I'm having a similar problem right now w/ the new slave on my 1991 wrangler. The new slave from Advance Auto has the quick disconnect that does not connect w/ the existing hose from the master cyl. No one at AA seems to know why the new slave is not compatible w/ existing hose and if there is an adapter. Very frustrating because the new clutch and slave are already installed and everything put back together except connecting the existing hose to the new slave. help!!!
davebl260 is offline
post #10 of 13 Old 08-27-2013, 10:14 AM
davebl260
Forgot to mention about removing the quick disconnect from new slave - I've tried using a line wrench but even with that I can't get it loose. Put so much pressure on it that the line from the slave started to bend so I stopped in fear that I would break it and have to start the whole job over again.
This picture shows the new slave lines next to the existing hose.
post #11 of 13 Old 08-27-2013, 03:26 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
My 91 leaked from that "quick disconnect" thingy after I put in a new clutch, master and slave. I ended up having Hose-Man make me a steel braided hydraulic line that replaced the existing stock line on the jeep. Over 2.5 years ago.. no issues. I found that I could not remove that "Quick Disco" from the stock line.
Not much help, but there was my solution. Hose cost me $90 with the rush order. I took them the stock line so that they could see the length and the connectors at both ends.
Best of luck.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #12 of 13 Old 08-30-2013, 05:41 AM
davebl260
Best of luck.
So the existing hose you see in my photo, is that what you had on yours? Getting mixed feedback from the forum but trying to determine if that existing hose is OEM to the '91 wrangler. If so then Advance needs to explain why they are selling a replacement slave that doesn't work without additional modifications.
post #13 of 13 Old 08-30-2013, 08:12 AM
Luuca
Luuca's Avatar
To be clear:
My hydraulic line from the master clutch reservoir was some sort of plastic molded line with a large quick disconnect thing at the end of it.
My throw out bearings both the old and new one I got from autozone did not have any quick disconnect on it.
Because my line was plastic, I didn't want to put too much force on it trying to remove the leaking quick disconnect section of the line.
I had a hose made to replace the line. The throw out bearing was correct.
In another thread, a member posted that you can remove the quick disconnect off the slave cyld side with "two wrenches".
Posted via my pretentious iPhone.
YJOTM Sept. 2017
Luuca is offline
Internal Slave Cylinder Pin? Tompatt YJ Wrangler Technical Forum 3 10-17-2009 03:12 PM
Internal Slave Cylinder MUDDYJEEP YJ Wrangler Technical Forum 1 12-30-2008 03:05 PM
internal slave cylinder.... trailrated1989 YJ Wrangler Technical Forum 6 01-27-2007 08:17 AM
internal vs external slave cylinder 91GTA350 YJ Wrangler Technical Forum 10 04-29-2005 09:14 PM
YJ internal slave cylinder JKNIPE2000 YJ Wrangler Technical Forum 10 03-04-2004 04:27 PM
