Internal Slave Cylinder Pin? - JeepForum.com
post #1 of 4 Old 10-14-2009, 03:58 PM Thread Starter
Tompatt
1987 YJ Wrangler
Putting the pin in the hole looks so easy. But somehow i can not do it. just wondering.. what does that lil pin holding the slave actually do? its not a tight fit it seems.. does it just hold the slave in place until its against the clutch? do i need it?
Thomas
-1987 YJ
Tompatt is offline
post #2 of 4 Old 10-14-2009, 04:16 PM
idaholtby
This roll pin keeps the slave from rotating. There should be a capture nut that slides over the slave body onto the roll pin to keep the slave from rotating. It is not a very tight fit, but it is necessary. Most clutch kits come with a new roll pin and capture nut that should be installed with the new slave.
idaholtby is offline
post #3 of 4 Old 10-17-2009, 04:11 PM Thread Starter
Tompatt
1987 YJ Wrangler
man.. this may be the worst part ever haha.. where can i get a new one? i think i messed the one they gave me up.
Thomas
-1987 YJ
Tompatt is offline
post #4 of 4 Old 10-17-2009, 04:12 PM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
Take the one you broke to the hardware store. I have found tons of little things like that at the local hardware hanks in town here.
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
Internal Slave Cylinder Question kdogg43 YJ Wrangler Technical Forum 4 03-24-2009 10:24 AM
Internal Slave Cylinder MUDDYJEEP YJ Wrangler Technical Forum 1 12-30-2008 04:05 PM
internal slave cylinder.... trailrated1989 YJ Wrangler Technical Forum 6 01-27-2007 09:17 AM
slave cylinder installation (internal) hmk_21 YJ Wrangler Technical Forum 4 08-08-2005 07:02 PM
YJ internal slave cylinder JKNIPE2000 YJ Wrangler Technical Forum 10 03-04-2004 05:27 PM
