Internal Slave Cylinder to External Conversion - JeepForum.com
post #1 of 6 Old 09-22-2008, 04:10 PM Thread Starter
glennda5id
I am having trouble with my internal slave cylinder and planning on doing the conversion to an external. I have a 93 with a 4.0L which I assume means that I have an AX-15 transmission. The only question I have is if I can use a bell housing from a 94+ ax-5, or does it have to be an ax-15? I only ask because I don't want to get the wrong one. Does it have to be a 94 and up 4.0L donor jeep? Also, what is the full span of years that is compatible? 94 - ?
Thanks
glennda5id is offline
post #2 of 6 Old 09-22-2008, 04:17 PM
Cobra Jeep
Yes, you will have the AX-15, and NO, you can not use the bellhousing from a AX-5.
You can use the bellhousing from 95 and up. Some late 94 model may have it, but make sure the seller sends you pics if your buying online. You can use one from TJ's and even one from a TJ NV3550. Thats what I am useing. The AX-15 and NV3550 use the exact same bellhousing.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #3 of 6 Old 09-22-2008, 07:25 PM
pat8942
pat8942's Avatar
94 to 2004 had the ax-15 and external slave.
All 1994 YJ's have the external slave not just late production.
As Cobra Jeep says 2005 and up with the NV3550 to when they dropped the 4.0 will also work.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #4 of 6 Old 09-23-2008, 08:19 AM Thread Starter
glennda5id
Thanks guys
post #5 of 6 Old 09-23-2008, 10:22 AM Thread Starter
glennda5id
Another question
Here is my parts list for the conversion. Does everything look right? Do you like the quality of parts that come from xtremeterrain? What about the delco clutches?
rockauto.com
Clutch Kit ACDELCO Part # 381194 () $125
-includes new release bearing
xtremeterrain.com
Master/Slave Assy. P/N 52104113 $120
Clutch Fork P/N 52107555 $29
Front Bearing Retainer P/N 4636382 $109
Front Bearing Retainer Seal P/N 5252053 $4
post #6 of 6 Old 09-23-2008, 11:00 AM
pat8942
pat8942's Avatar
That parts list looks surprisingly familiar.
I'm not familiar with the AC Delco clutches,but it's probably as good as any other.
I used the exact parts from xtremeterrain 4 years ago when I did my conversion and everything still works as good as the day I did it.
I have never had any problem with the clutch and I have never had to add any fluid to the master over the 4 years since I did it.
rockauto.com
xtremeterrain.com
pat8942 is offline
AX-15 Internal to External Slave Cylinder Clutch line write up bigredcherokee YJ Wrangler Technical Forum 40 11-15-2014 03:10 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 10:26 AM
internal vs external slave cylinder 91GTA350 YJ Wrangler Technical Forum 10 04-29-2005 09:14 PM
internal to external slave conversion johnny1720 YJ Wrangler Technical Forum 5 02-05-2004 09:32 PM
Internal to external slave cylinder conversion? SBall YJ Wrangler Technical Forum 4 01-17-2002 08:53 PM
