Internal Slave Cylinder blew up? - JeepForum.com
post #1 of 22 Old 06-10-2013, 09:17 PM Thread Starter
caoboy
Internal Slave Cylinder blew up? Time to change the clutch! (2.5)
Driving to the lake on Sunday led to this:
From what I understand, the Internal Slave Cylinder (forever known as the ISC from now on) just expelled all fluid, leaving my clutch soaked, and the pedal on the floor.
I haven't pulled the trans, but that is what I've hypothesized due to fluid dripping out of the bell housing, and it not being in the reservoir.
From what I've searched on about the ISC through this forum, the fastest way to alleviate the problem is to either burn the Jeep to the ground, or sell it and buy a newer model with an external slave cylinder.
That being said, if I don't choose to go either of those routes, I'll need a new clutch (kit) and ISC.
(Clutch kit from RockAuto.com)
EXEDY Part # 01033
Includes Slave Cylinder; Disc mm 225; Disc in 8-7/8; Splines Dia 15/16; Splines 14; Islander; S Model; Sahara; Base Model
It's $160, a good brand that hasn't failed me in the past. Those replacements were on Hondas and Nissans, and cars to boot. I don't know how it will hold up to the POWER of the 2.5 liter engine.
Anything else I'm going to need? I know I'll need to either get my flywheel resurfaced or replaced, and new trans fluid, transfer case fluid, clutch fluid, and a whole lot of degreaser.
Should I change out the rear main seal while I'm in there? I'd hate to have to pull out this trans more than once.
Any tips, tricks, or donations are always handy.
caoboy is offline
post #2 of 22 Old 06-10-2013, 11:41 PM
jokerchief462
No they are real good from the factory my original went 120K until I swapped up to an external mod with parts from a 94. Yeah they are a PIA and they are also touchy when you take it apart you will see the hokey setup with O-rings and a clip for the input line. Get a trans jack from harbor freight makes it a lot easier it was only $75 and I use it all the time. I am too old to be bench pressing trannys anymore.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 22 Old 06-10-2013, 11:49 PM Thread Starter
caoboy
Yeah I was thinking about the transmission jack...I might as well pick one up.
caoboy is offline
post #4 of 22 Old 07-26-2013, 06:21 PM Thread Starter
caoboy
Here we go.
Transmission jack has been purchased.
Ordered a clutch kit, master and slave cylinder, and flywheel, $215 shipped from Rock Auto. Gotta love that site!
It's probably best I change all these parts out for new ones, I don't want to have to drop the transmission a second time, I don't know how old any of the parts are.
Anything else I should do while I'm in there?
caoboy is offline
post #5 of 22 Old 07-26-2013, 07:32 PM
roadyrob
1987 YJ Wrangler
as your changing the flywheel I think you pretty much have all the parts covered. I'm about to do the same job on my 87 4.2, my slave went out today. I also ordered from rock auto.
one trick I learned the last time it went out, just start it in gear, drove mine home about 10 miles, a little tricky shifting without the clutch but it can be done.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #6 of 22 Old 07-26-2013, 08:51 PM
Reno72
Why not covert to 95 external slave? New bell housing and MC and no more internal crap.
Reno72 is offline
post #7 of 22 Old 07-26-2013, 09:25 PM
ejeeperguy
1982 CJ7
I had the misfortune to get two bad ones .The third one that is in it now has held up nicely. Had to put one of them in after getting back from the middle East with a hand injury made it that much more fun doing it with the use of one hand.
ejeeperguy is offline
post #8 of 22 Old 07-26-2013, 11:17 PM Thread Starter
caoboy
Well that sucks! I hope I don't run into that same issue...any idea why they were bad?
My reason being is that while I can take my time to get this back on the road, I don't really want to spend a time searching for a bunch of stuff to convert the AX5 to an external slave setup.
Had I an AX15, and a 4.0, that'd be a different story. I will be looking into the 4.0/AX15 swap in the (near?) future...
caoboy is offline
post #9 of 22 Old 07-26-2013, 11:19 PM Thread Starter
caoboy
I didn't want to chance it driving 15 miles home, the AX5 is supposedly weak, and I'd rather not blow that out too. Although I'd have an excuse for an upgrade!
caoboy is offline
post #10 of 22 Old 07-27-2013, 12:02 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I drove my Yj from Md to Tennessee with no slave cylinder (line blew ) it had a ax5 and I was towing a trailer match your revs per gear and it'll slip right in gear.
I find myself shifting a bunch in my 89 with ba10 with out the clutch quite often also. I guess I've been driving a Stick way too long and know my vehicles sweet spots
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 22 Old 07-31-2013, 10:47 PM Thread Starter
caoboy
All the purchased parts have arrived!
caoboy is offline
post #12 of 22 Old 08-03-2013, 06:21 PM Thread Starter
caoboy
Transmission is out, clutch is out, flywheel is out. I took a bunch of pictures, I'm hoping they'll be enough for a halfway decent write-up. I'm having an issue with the master cylinder, but I may pull that with the line attached and pop the roll pin out on the bench.
I officially hate the JEEP assembly line of Canada, I'd appreciate if they put change out either the metric, or standard, bolts so that they may ALL BE THE SAME STANDARD OF MEASUREMENT!!
It's break time and pizza is hitting the spot.
I'm also looking for info on how to put in the new pilot bearing. I noticed it's in the old flywheel, but mine isn't already installed.
caoboy is offline
post #13 of 22 Old 08-03-2013, 06:48 PM
jokerchief462
Pilot bearing no problem mine went in easy. A little light oil on the flywheel
Put it in best you can by hand and then tap in
If needed use a socket same size and finish
post #14 of 22 Old 08-03-2013, 06:50 PM Thread Starter
caoboy
Thanks!
Again, thanks for the advice on the transmission jack, probably the best investment for this swap, it was nice being able to just adjust the transmission up and down to get the top bolts out...(which are a total PITA!)
caoboy is offline
post #15 of 22 Old 08-03-2013, 06:57 PM
roadyrob
1987 YJ Wrangler
for the pilot bearing find a socket that is slightly smaller diameter than the bearing and drive it in. just did mine today only on the 6 cyl its in the crank not the flywheel so I had to remove the old one first. packed it full of grease and used a bolt that fit tight and hit it and it popped out, thanks for the tip jeep forum.
roadyrob is offline
