My internal slave cylinder was leaking. So I dropped my tranny.. all day affair. But anyways changed the slave cylinder/throw out bearing. But everything back in. Went to bleed the brakes. Now it leaks worse. Any ideas?
obviously you are going to have to pull it apart again :brickwall -- that blows -- but hey, search the forum here and do the cherokee external slave swap -- I have read here it is cheap and easy to find the used parts. Keep us posted.:2thumbsup:
Sorry about the type-o. I ment bleed the clutch system. But it leaks really bad now. Can I buy just the lines. Or do I need to return the one I got last week... Or what? Well tomorrow I am taking it to the hobby shop on base.(lift, tons tons and tons of tools. Everything else you might need need.) When I drop it I am going to re hook up everything out side of the bell housing and see whats leaking. Thinking for everyones input.
since your taking it apart again anyway and chances are you got brake fluid on the clutch disc, you might as well replace the clutch while your there.
The slave cyl quick connects can be quite a pain to reinstall, be sure they are fully engauged, and have the orings on them.
Good luck
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
