Internal to external slave cylinder conversion? - JeepForum.com
post #1 of 5 Old 01-14-2002, 12:17 PM Thread Starter
SBall
Hey everyone,
I have been reading this board for a while and some of you seem to have a lot of mechanical know-how. I have a 92 YJ with the 4.0L and 5-speed AX-15. My internal slave cylinder has gone out again, and I really want to convert to an external slave-my transmission is in good shape, so I dont want to get a new one. I think I can get the bellhousing from a 94-99 and the external slave and I should be good to go, but Im not sure if this is a plausible solution. But I can't find any good write ups with my transmission. I found a couple for the AX-5 but Im not sure how accurate they are. First of all, I am wondering if this is possible. And second, if it is, I am not sure which parts I would need to get and which I could re-use out of my clutch mechanism(clutch fork, throwout bearing, etc.). And as long as I am in there, Im afraid I will be forced to upgrade to a Centerforce II-dang, I hate that. Any advice or information any of you have would be great. Thanks for your help.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline
post #2 of 5 Old 01-14-2002, 10:59 PM
snakeroo
Hey, Im trying to do same thing.
And ive posted the question on a couple different msg boards. A couple ppl hv already responded, one saying its been done alot.
U can read the msg's here.... http://forums.jeepsunlimited.com/ubb...ML/000612.html
~Kara(snakeroo)
Blue 1993 Wrangler YJ, 6cyl, 4.0L 5spd, 140K miles.
snakeroo is offline
post #3 of 5 Old 01-15-2002, 09:34 AM Thread Starter
SBall
Thanks so much. I feel much better about this project. That other message board was definitely helpful. I called No Excuses and talked to the guy and he answered all the questions that I threw at him. Good luck on your conversion. If you get it done anytime soon, let me know how it went.
SBall is offline
post #4 of 5 Old 01-15-2002, 09:36 AM
bob91yj
Besides the bell housing, and the external slave components, you will also need the front bearing retainer from the donor transmission. Pretty straight forward conversion.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #5 of 5 Old 01-17-2002, 08:53 PM
snakeroo
Just letting yas know, First Class is sending me a 1998 Bell housing and throw-out arm. And Ive made an appt with No Excuses for next week. They have all the other parts and they will do the job, no prob.
Thanks,
~Kara(snakeroo)
snakeroo is offline
AX-15 Internal to External Slave Cylinder Clutch line write up bigredcherokee YJ Wrangler Technical Forum 40 11-15-2014 03:10 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 10:26 AM
Internal Slave Cylinder to External Conversion glennda5id YJ Wrangler Technical Forum 5 09-23-2008 11:00 AM
internal vs external slave cylinder 91GTA350 YJ Wrangler Technical Forum 10 04-29-2005 09:14 PM
internal to external slave conversion johnny1720 YJ Wrangler Technical Forum 5 02-05-2004 09:32 PM
