Intermittent wipers quit - JeepForum.com
post #1 of 5 Old 10-13-2005, 09:23 AM Thread Starter
crglidden
The regular low and high wipers work, but the intermittent wipers do not through out the range. It used to work sometimes and then it would just stop in the middle of the windshield. Finally it just up and quit. Any ideas as to why? Think it's the wiper motor or wiper motor relay? Thanks in advance!
crglidden is offline
post #2 of 5 Old 10-13-2005, 09:37 AM
RCHavok797
RCHavok797's Avatar
There is a module under the dash for the intermittent wipers. Check to see if the plugs are fully seated and if they are then possibly this module is bad. It should be located right below the steering wheel mounted on top of a metal plate.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 5 Old 10-13-2005, 09:41 AM Thread Starter
crglidden
Thanks, I'll check that when I get home from work.
post #4 of 5 Old 10-13-2005, 09:47 PM
copscott76
Do you know if there is the same kind of module on an 87 YJ? If so, were exactly is it under the dash?
copscott76 is offline
post #5 of 5 Old 10-13-2005, 09:52 PM
BuffaloYJ
BuffaloYJ's Avatar
I yanked my intermittant module when mine quit. Poppes it open and some of the parts on the circuit board were fried...haven't quite gotten around to replacing it but I looked into it once and the module was around $80. The module is inline on the wiper circuit so you can just plug the harness together with the module out and still just have hi and lo.
BuffaloYJ is offline
Intermitant wipers quit StreetbikeDepot YJ Wrangler Technical Forum 20 11-13-2008 04:55 AM
Wipers quit working udtoy YJ Wrangler Technical Forum 1 11-19-2007 12:07 PM
HELP wipers quit today Robbypfd YJ Wrangler Technical Forum 1 10-17-2007 09:26 PM
Wipers quit whyjay YJ Wrangler Technical Forum 12 06-29-2007 12:14 PM
97 TJ--- Windshield wipers just quit!! tps7c TJ Wrangler Technical Forum 11 11-10-2006 08:09 AM
