Intermittent starting problem... - JeepForum.com
post #1 of 11 Old 03-24-2007, 12:06 AM Thread Starter
squattingdog
I am trying to track down the problem with my 90 YJ not starting every now and then... couple of questions:
How much power should run to the fuel injector? If no power, does that mean a bad ECM?
...The engine will turnover constantly and not fire. Then the next day it starts up just fine! Thanks in advance for any help...
squattingdog is offline
post #2 of 11 Old 03-24-2007, 04:37 AM
Jeep25
If the engine is turning I don't think it's a bad ECM?
Jeep25 is offline
post #3 of 11 Old 03-24-2007, 05:34 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
We need more info, Engine, trans, mods to the engine, when maint was done, etc.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 11 Old 03-24-2007, 06:07 AM
BASSPLAYER1
I had the same prob. when it got cold out it waseven worse!!! It was my computer!!!! I own a 95 yj 2.5 5 speed.
Good Luck
BASSPLAYER1 is offline
post #5 of 11 Old 03-24-2007, 10:59 AM Thread Starter
squattingdog
Stock 2.5L engine, stock AX5 tranny, with split fire spark plugs, msd 8mm wires. Regular maintenance is kept up. ...I posted this thread last night and now it is running??
post #6 of 11 Old 03-24-2007, 11:05 AM Thread Starter
squattingdog
Good Luck
How can you test the computer? Is it a driveway job or is there special tools involved?
post #7 of 11 Old 03-24-2007, 03:57 PM
MudDancer
I had similar problem with my 87 YJ, 2.5l 4banger, TBI, stock. I thought it had something to do with my fuel pump. What I found was 2 Relays that transmitted electrical signals to componets (such as fuel and ignition). Also known as (ASD) Auto Shutdown relay. They are located on passenger side next to battery, one was black the other blue plugs. the cost was around $8.00 each. After replacing them my problem was cured.
MudDancer is offline
post #8 of 11 Old 03-24-2007, 11:38 PM Thread Starter
squattingdog
Well i will definitely will replace them and keep the progress posted....thanks
post #9 of 11 Old 03-27-2007, 03:41 PM Thread Starter
squattingdog
..Replaced both the relays...nothing has changed The same problem still exists...maybe a 12 pound hammer??
post #10 of 11 Old 03-27-2007, 05:15 PM
idiot magnet
I went through something like this last week, but when I traced the wires going to the fuel pump I found a 4 foot section that was dead.
Check to see if you are getting power to the fuel pump, clean your crank position sensor, clean all your grounds and connections, check for cracks in the distributor cap and see if the rotor is good.
I started replacing too many things and it was a simple piece of new wire and she starts and runs everytime. Trace all the wires to the pump and test them every foot. There is a section that wears out just above the rear axle where the wire rubs on the frame. Mine wore through the plastic protector.
It's worth a shot and at least you'll know if you have power to the pump, then you can eliminate other things as you go.
Good luck.
A rebuilt '05 Unlimited w/ 6 spd, 4.0, 3" BDS springs, front locker, warn front bumper, PS corners, rock sliders and the list goes on and on.
Former Jeeps: 79 CJ7, 81 CJ7 Renegade, 85 CJ7 and a 95 YJ.
Project car: Big Block 4spd 69 mach 1 (it's back on the rotisserie for the final time).
Indyorv.com
idiot magnet is offline
post #11 of 11 Old 03-27-2007, 08:51 PM Thread Starter
squattingdog
I appreciate the help... will definitely check this tomorrow...I'm sure if the problem persists then I'll be back on here asking more questions lol
Intermittent starting problem - need help! dabrogger TJ Wrangler Technical Forum 1 06-03-2009 11:14 PM
Intermittent starting problem. Talos YJ Wrangler Technical Forum 5 01-06-2009 12:26 AM
Intermittent hard starting TJ_Jackson TJ Wrangler Technical Forum 4 08-02-2008 07:24 PM
Intermittent Starting Problem Wrangler95CSA YJ Wrangler Technical Forum 20 01-08-2008 06:00 AM
Intermittent Starting Problem aero91 YJ Wrangler Technical Forum 2 04-16-2004 04:42 AM
