Intermittent stalling problem. - JeepForum.com
post #1 of 3 Old 08-31-2011, 01:18 PM Thread Starter
Badgerstripes
1995 jeep wrangler, 2.5; intermittent stalling; fuel smell; codes read as follows: 12-beginning; 33- A/C (None) 22-MAP vacuum, 23-CTS, I think, 24-MAT sensor; 54-don't know; 22 again, 24 again, 13- , 24 again, 55-End. Sometimes won't start at all after stalling, sometimes right up again. Cannot get it to start with popping the clutch-sometimes will get it to start, while it's coughing and snorting, with the ignition (yes it grinds a bit). And loosy goosy wiring harness on right side of engine compartment can sometimes be 'jiggled' to get it start up again.
Coolant temperature gauge is operating but not reading much, all other gauges functioning and inspection of printed circuit on back reveals no damage/short. Coolant temperature sensor replaced about 8 weeks ago, prior to 2400 mile round trip with no problems, but didn't change gauge reading.
Over life of vehicle following sensors have been replaced: Crank Pos. Sensor, CTS(as mentioned), IAC, TPS, Ignition Coil (Including the mounting bracket which cracked once), distributor pickup, alternator, battery couple of times. MAP and MAT sensors have never been replaced.
Ideas?
Badgerstripes is offline
post #2 of 3 Old 09-01-2011, 01:45 PM Thread Starter
Badgerstripes
Update. Gauge not related. ECU might be.
Got a new MAP sensor, now the stall is "hard", that is, no coughing and sputtering to a weak death. So I was troubleshooting multiple issues.
Found out my gauge issue is completely unrelated, it has a separate sending unit, that will get installed tonight or tomorrow.
Found out that the ECU's have 'shorting' or solder-breaking-loose issues sometimes. May or may not be my problem. Will disconnect the wiring harness, clean the connections and dielectric-grease-it-up to see if problem diminishes.
post #3 of 3 Old 09-01-2011, 02:54 PM
oldtime_ironman
Betting you got a bad connection over there where the wiring harness is loose - that's right where the computer is.
oldtime_ironman is offline
97 TJ 4 cyl.- Code 43, Intermittent stalling freedom2009 TJ Wrangler Technical Forum 2 06-25-2008 04:41 AM
Intermittent stalling foneman YJ Wrangler Technical Forum 7 08-18-2007 12:28 PM
Intermittent Stalling Problem Rutnbuck TJ Wrangler Technical Forum 2 01-03-2007 06:44 AM
Intermittent 2000 TJ Stalling Issues szpynda TJ Wrangler Technical Forum 2 10-17-2006 10:19 AM
Intermittent stalling jeepfury YJ Wrangler Technical Forum 0 05-22-2005 06:51 PM
