Intermittent Speedometer issue - JeepForum.com
post #1 of 7 Old Yesterday, 04:44 PM Thread Starter
BadPanda
Have a weird issue that hopefully you guys can shed some light on with my 95 YJ 4.0. For about the last year or so, my speedometer has been acting up. When first driving it the speedometer will not move for maybe a couple miles or so and then it would kick to life and stay alive/accurate until I turn the car off. Sometimes if the car was still warm it would work again on the next start up, but if I let it sit for a bit the speedo would not read until a number of miles into the next drive. When the problem first started, it the speedo would kick in before getting out of my neighborhood. With time I would have to keep driving farther and farther for it to start working. All the other gauges/lights work.
Spinning the gear with a drill does not make the speedo move
What I have done so far..
Replaced the VSS
Replaced speedo gear
I removed the cluster to check the copper wiring and the only pathway that has a little scuffing looks to be going to the lights and not the 3 prongs of "IGN/SP or GND". I tried the eraser anyways and had no luck.
Besides blindly swapping the cluster, can anyone else think of something? I have not tried to trace the wiring from the VSS.
Thanks for any advice
BadPanda is online now
post #2 of 7 Old Yesterday, 05:53 PM
jtec
what model year?
OK as you spin the gear Is the VSS generating a signal?
jtec is online now
post #3 of 7 Old Yesterday, 06:13 PM Thread Starter
BadPanda
1995, will edit the first post to reflect that.
When you say generating a signal I am guessing that you mean making the speedo move, it is not.
post #4 of 7 Old Yesterday, 06:31 PM
rocketboy
rocketboy's Avatar
Originally Posted by BadPanda
1995, will edit the first post to reflect that. When you say generating a signal I am guessing that you mean making the speedo move, it is not.
I think he means if you hook a meter up to it, does it generate a signal.
Seems like there are three things that could be the problem: the VSS isn't generating a signal, the speedo is broken, or there's a wiring problem somewhere in between.
So the first step would be to figure out if the VSS is generating a signal.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is online now
post #5 of 7 Old Yesterday, 06:57 PM Thread Starter
BadPanda
Gotcha, with the speedo cluster removed and jeep running I am getting around 6.5 volts on the orange wire and around 4.5 on the white/orange.
post #6 of 7 Old Yesterday, 10:20 PM
rocketboy
rocketboy's Avatar
So I think you need to spin the gear and see if you get a change.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #7 of 7 Old Today, 07:02 AM Thread Starter
BadPanda
Alright, I am confused then. I can measure the readout up by the cluster for both those wires while spinning the gear, but how am I to do it down by the VSS if everything is plugged in? I suppose that I could remove a chunk of the wire insulation, or am I totally missing something?
Edit: Found this for anyone looking in the future, gonna play around
http://jedi.com/obiwan/jeep/instclust/
BadPanda , TSEJEEPERS
