Interior pictures - Page 3 - JeepForum.com
post #31 of 45 Old 01-30-2006, 02:03 PM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
Originally Posted by jwicker
quoted........
SimonTuffGuy is offline
post #32 of 45 Old 01-30-2006, 02:47 PM
superjoe
superjoe's Avatar
wow i just realized that i dont have any interior pics. i need to snap some later and ill post them
Joe Clark 210-639-0276
/l ,[____], 82 CJ 8 Scrambler Currently all stock but that will change.
l---L--0lllllll0-
()_) ()_)----)_)
superjoe is offline
post #33 of 45 Old 01-30-2006, 03:43 PM
that_1_guy
Someone asked before about a cleaner for interior: Armorall (sp?) has wipes out now that clean instead of polish. These take everything off. It leaves a real dull finish though on acount of it takes all of the oils and stuff out of the plastic. Just wipe it down with polish wipe after the cleaning ones and it turns out excellent!
'94 Red YJ
4-banger (2.5L) 5sp/3" bl with 31" bf/mt
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
Red Jeep Club Member #318 | Low Output 4-Banger Club Member #46
that_1_guy is offline
post #34 of 45 Old 01-30-2006, 03:45 PM
rare-renegade
rare-renegade's Avatar
Here's mine complete with golf ball shifter knobs.
1991 Renegade, 4" Rough Country Lift, 32" A/T's on 15x8 Canyons, Fr. Runk Bumper, Rear Warn Rock Crusher Bumper, Ramsey 6000# Winch, 4.10 YJ Axles, Blower Mtr. Upgrade, 150 AMP alternator, ZJ Rear Disc Brakes w/Corvette MC, CB w/Firestik, Half Hardoors, Warn Steering Box Guard, KC Highlights.
rare-renegade is offline
post #35 of 45 Old 01-30-2006, 05:06 PM
94YJ H.O.
rare-renegade:
I really like those gauges. Where did you get the overlays from?
1994 YJ 4.0 H.O.
3-speed Auto
My NEW
Score: 406RRv1.0 with a BOA of 31.60
94YJ H.O. is offline
post #36 of 45 Old 01-30-2006, 05:25 PM
standnstillfast
you can get those overlays at www.4x4mods.com they're cheap and aren't too bad
1989 YJ, 3.5 BDS lift, 2" BL, BDS steering stabilizer, 5/8 MORE shackles, CRT HEI, 35 x 12.5 BFG A/Ts , soft 8's, IPF H4 headlights, Weber K551, dynomax exhaust. Herculined tub, neoprene seat covers, white gauges, JBL speakers, overhead console, and much more
standnstillfast is offline
post #37 of 45 Old 01-30-2006, 05:31 PM
tube yj
tube yj's Avatar
1949 CJ3A
here is my interior. Stock gauges no plastic on the dash. tuffy glovebox, Quick disconnect steering wheel, aluminum sprint car wheel
tube yj is offline
post #38 of 45 Old 01-31-2006, 12:59 AM
MendoXJ
88' YJ
1988 YJ 4.2
D44 Rear w/moser 30 splines and Detroit
HP30 Front with lockrite
36x12.50 Super Swamper TSL SX's
Poison Spyder Comp Stinger
MendoXJ is offline
post #39 of 45 Old 01-31-2006, 04:37 AM
JustPassinThru
OHHHH, my EYES!! *yarkkkk*
You shoulda mounted the TJ cluster on a steel panel, CJ-style.
Not trying to diss your work. It's just that I HATE the TJ interior...if I wanted to drive a Plymouth, I'd have BOUGHT a Plymouth! The TJ interior is just so...so anti-Jeep...
JustPassinThru is offline
post #40 of 45 Old 01-31-2006, 07:38 AM
jwicker
The dash vents alone will make it all worth while sa the temp continues to drop.
I had considered several other options before swapping dashes... putting the TJ cluster where the YJ guages were. Also considered cutting the dash pad above the steering wheel and fabbing a fiberglass surround for the TJ cluster.
Neither of which would have worked as well as I wanted.
I actually had to relocate the YJ wiper motor to the passenger side and reverse and cut one of the wiper linkage rods. The TJ cluster was way too thick to fit with the wiper motor in its stock location.
At the same time, I found a great deal on a brand new heater assembly from a TJ. Swapped that too.
So I should have plenty of heat and the dash bents, cluster, etc.
I know that some really dig the metal CJ style dashes...but to each his own.
Wanna buy a YJ dash?
jon
Jon Evansville, Indiana
87 YJ/TJ Morph
3" (damned old) body lift, 1" Extended shackles, 1.5" Rough Country leaf springs, MP fuel injected 4.0, 3 row radiator, 33x12.5x15 ProComp X-Terrains, Eagle Alloy 8 Holes 15x10, Champion Winch, TJ Dash, 92 Roll Bar, AX15 5 speed, Posi-Lok, 1997 Dash and heater
jwicker is offline
post #41 of 45 Old 01-29-2013, 03:11 PM
Lireb93
YJ six speaker Sound Bar with Dome Light
Originally Posted by toplessjeep View Post
I spliced mine into the actual interior light under the dash. So not only does the light go on when the door opens but it goes on when I turn the dimmer switch.
I am trying to do what you did to get the lights to work as you did with the doors open and the dimmer. Have only two wires coming from the sound bar dome light. Red and Black. If possible could you walk me through the procedure? Thanks in advance.
Lireb93 is offline
post #42 of 45 Old 01-29-2013, 06:14 PM
Mark05059
this thread is 7 years old...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #43 of 45 Old 01-30-2013, 02:36 AM
SunDevilJeeper
7 years old? How about another bump!
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #44 of 45 Old 02-02-2013, 10:36 AM
Lireb93
Got it. Thanks
Lireb93 is offline
post #45 of 45 Old 02-02-2013, 11:37 AM
roadyrob
1987 YJ Wrangler
black is ground red is hot. take a test light and probe the wires going to the door switch to find the hot when the door is open, not hot when its closed, tie into that, ground the black wire and you will have a light that comes on when you open a door and is also controled by the dimmer switch.
and you didn't have to wait 7 years for an answer.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
interior bambam4442 YJ Wrangler Technical Forum 7 06-17-2008 09:30 PM
Yj Interior Brandon_YJ YJ Wrangler Technical Forum 24 12-13-2007 08:39 AM
My jeeo pictures and interior assets :-D MMerrick YJ Wrangler Technical Forum 16 05-19-2007 08:49 PM
Pictures of you khaki interior please.. 04JeepTJ TJ Wrangler Technical Forum 6 02-03-2004 10:29 AM
interior pictures BSUCrew YJ Wrangler Technical Forum 6 02-20-2003 09:54 AM
