Interior light not working - JeepForum.com
post #1 of 9 Old 11-09-2013, 08:27 AM Thread Starter
kylebeau
I was trying to put in led strips to replace the crappy two light bulbs. They were working fine but then my friend decided he wanted to see what would happen if he touched positive to negative and needless to say now they don't work. We checked all the fuses and none of then are blown. What do could the problem be?
kylebeau is offline
post #2 of 9 Old 11-09-2013, 08:44 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Make your friend fix it.
Luck Favours The Prepared
Anticanman is offline
post #3 of 9 Old 11-09-2013, 08:48 AM
psyco31
I would think that he fried the led diods
psyco31 is offline
post #4 of 9 Old 11-09-2013, 09:35 AM
Beaveranger
Then punch him in the neck for being such a dumba** j/k
There's only one thing I hate more than lying. SKIM MILK
Which is water that's lying about being milk....
~Ron Swanson~
Beaveranger is offline
post #5 of 9 Old 11-09-2013, 11:56 AM
sprngrider
Leds do not blow out if the polarity is reversed in DC, it is one of the good things about them. Its a fuse problem because your friend shorted the circuit. It is probably a mini fuse under the hood.
1994 2.5L WRANGLER S.
sprngrider is offline
post #6 of 9 Old 11-09-2013, 12:03 PM Thread Starter
kylebeau
Do you know which one it would be?
kylebeau is offline
post #7 of 9 Old 11-09-2013, 12:07 PM
sprngrider
Are they switched on with the stock dimmer switch? Or a switch that you wired in yourself? I think the stock switch fuse is just below the dash on the firewall. Not too sure on the location, its been a while. It will be a 5 or 10 amp fuse.
post #8 of 9 Old 11-09-2013, 12:40 PM Thread Starter
kylebeau
It's with the stock switch
kylebeau is offline
post #9 of 9 Old 11-09-2013, 06:21 PM
psyco31
That is good info to know. Thanks for the correction
psyco31 is offline
