Interior light issues - dome light and wiring mess - JeepForum.com
post #1 of 1 Old 07-20-2009, 07:47 AM Thread Starter
liminalhigh
I'm trying to get the dome light in a sound bar working with my softtop. Due to the current state of my interior 'courtesy' lighting (this is the drivers side: wire cut, not plugged in, light exists but doesn't work. On passenger side the wiring is intact but has no bulb/fixture):
http://farm3.static.flickr.com/2604/...b68bbb7b31.jpg
... we thought it would be easiest to wire it into the rear hardtop wires/harness. When the hardtop is on, I can turn the rear HT dome light on via the dimmer switch in the dash. This is the only way the HT light can come on and it doesn't matter if keys are in ignition or not.
The problem is now that we've wired the soundbar light into the rear harness (pink wire), it's a constant feed and the light stays on no matter what we do with the dash dimmer switch.
The sound bar wires are yellow (ground) and red (assumed power). Why would the HT dome light work (turn on/off) but the soundbar light constantly stays on? What are we missing? Thanks!
liminalhigh is offline
dome light issues.. help? rockaholic18 TJ Wrangler Technical Forum 8 11-19-2009 06:39 PM
Cj Top? Help with dome light and wiring provinT13 YJ Wrangler Technical Forum 7 07-16-2009 07:26 AM
Need Help Wiring This Dome Light cmsurfer YJ Wrangler Technical Forum 12 05-21-2009 04:54 AM
Interior dome light on a 08 Sahara RonKZ650 JK Wrangler Technical Forum 5 02-03-2008 08:13 AM
Need interior lighting or dome light. erikfromtexas YJ Wrangler Technical Forum 9 12-31-2002 03:45 PM
