Interior Door handle - JeepForum.com
post #1 of 6 Old 09-26-2005, 11:03 AM Thread Starter
92wrangler
Hey guys well my interior door handle broke. The plastic peice is gone and there used to be 2 wires you could pull. One to unlock the door and one to open the door. I locked the door a few days ago and now the second wire is gone to unlock the door. Is there anyway to unlock the door. The outside lock is messed up and the key won't work. thanx for any info.
2001 Grand Cherokee Limited v8 4.7L H.O Black, leather, fully loaded, tinted windows all the way around
1997 camaro Z28 Fully forged 355, Stage 3 heads, Gm847 cam, Nitrous,
92wrangler is offline
post #2 of 6 Old 09-26-2005, 11:21 AM
jonnyri
jonnyri's Avatar
I can't remember exactly but....
if it's a full door (like your pics) you should be able to pull the inside cover off and get at the locking mechanism from the inside. Will be fun to pull off the interior of the door with it shut, but can be done. The interior panel can be removed by gingerly pulling along the edge - start at one of the bottom corners and pull out - if it's like mine the top slides into a chrome channel.
Dirty, rusty, banged up YJ.
OSJ / NEA Delegate
jonnyri is offline
post #3 of 6 Old 09-26-2005, 11:23 AM Thread Starter
92wrangler
ok thanx. I guess i will have to try that tonite when i get home.
post #4 of 6 Old 09-26-2005, 03:31 PM
ditchdoc
ditchdoc's Avatar
The problem with that is when you get that panel off there is a metal panel behind it that has to come off. The door has to be open because there are 2 screws on the edge of the door you can't get to them with it closed. The rods should still be in the doors just need to find them and put them back where they belong.
Jason
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
CSA Jeepers Association Member #6
ditchdoc is offline
post #5 of 6 Old 09-26-2005, 03:47 PM
sunny_8
Same thing happend to me.....you can push the lock by the door from the inside...its kinda hard, but you can and the door will swing open. Look at the point where the door hits the side of the jeep and see how it works, you will see what part you can move....
good luck...i am going to try and install my new handle tonight.
sunny_8 is offline
post #6 of 6 Old 09-26-2005, 03:56 PM
pyro9862
Just remove the panel, you don't just pull on it or you could mess up the mounts. Pull it out gently, and put a screwdriver behind it, slide it until you find the clip holding it on then pry out gently on the clip not the door panel.
Once it's out you can acess all the rods and you can unlock it and pop the door open.
pyro9862 is offline
Interior Door Handle breaking sreno YJ Wrangler Technical Forum 24 01-10-2014 06:27 AM
Help with replacing interior door handle... ChrisX Wrangler General Discussion 0 08-23-2009 08:25 AM
Interior door handle slaphands TJ Wrangler Technical Forum 2 01-01-2009 10:20 PM
Interior door handle 92wrangler YJ Wrangler Technical Forum 6 06-22-2005 07:41 PM
Interior door handle? tire_smoke YJ Wrangler Technical Forum 2 03-10-2003 07:28 AM
