Intake vs Carb vs Cam - Page 2 - JeepForum.com
post #16 of 21 Old 10-11-2010, 09:10 PM
Old4X
1990 CJ7
Originally Posted by Corpus89YJ View Post
If you can give me some quick direction on uploading pictures I will add a picture of the head gasket as well as a picture of the block
The forum software won't let you post pics early on .
You can upload the pics here
TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
And post a link to each photo.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #17 of 21 Old 10-12-2010, 05:50 AM Thread Starter
Corpus89YJ
Here are the pictures of the head gasket and the engine block.
Corpus89YJ is offline
post #18 of 21 Old 10-12-2010, 05:54 AM Thread Starter
Corpus89YJ
If someone can come up with something better to do with it than pull it and re-ring it, I am all for it. I dont really mind doing it, but I am not totally convinced that it is going to fix the problem and that is a lot of work just to hope it gets better. I said earlier that after it runs for about 5 minutes there is already oil coming out of the fill plug, some other places it comes out that I can see are the dipstick tube and the vent on the back of the valve cover. Also, I started it the other day (after the head gasket was replaced) and I didnt have the air cleaner housing on and it blew the pvc out of its grommet. I am starting to think that when I pull the oil pan I am going to find parts of rings laying in it, or find that whomever did the engine work the first time put the rings on in the wrong order or upside down or something.
For the record, the odo shows right around 200,000 on it but the engine has been rebuilt before. You cant see it in the picture but the piston says its .40 over.
post #19 of 21 Old 10-12-2010, 08:16 AM
Old4X
1990 CJ7
The head and the pistons all look brand new and you can still see the cross hatching in the cylinders. I bought the Jeep from a guy that used it as a hunting vehicle and I talked with his mechanic and they estimate that the motor has roughly 30,000 on it.
then:
This changed everything. A field overhaul that is blowing head gaskets indicates a botched job.
Everything on that engine would be suspect in my book. Rather than spend money on that one, I would consider finding another engine. Maybe your accessories can be re-used.
Old4X is offline
post #20 of 21 Old 10-12-2010, 03:22 PM Thread Starter
Corpus89YJ
Ok for those of you helping me out, thank you. I got on Craigslist and found a cheap 4.2 that a guy is selling. I do have a question though. His has a plastic valve cover and mine is aluminum, are these interchangeable? I still think I am going to pull the motor and rebuild it, but this way it will give me time to get it machined and done correctly this time. I guess the reason I am asking about the valve cover is because I could just swap them as I get closer to completing the rebuild. The guy has an offenhauser intake and a header that go with it but everything is from an 85 model. Do you guys see any problem with swapping out parts from an 85 to an 89? In the pictures of the 85 it looks like the fuel pump is on the opposite side of the block and some other minor differences, should I expect to have to modify the wiring harness for different sensors and stuff or is all of that going to be in the same place.
Thanks in advance.
post #21 of 21 Old 10-12-2010, 05:34 PM
4.7stroker
The valve covers are not a straight swap as far as I know. If I was building that motor I would install a 4.0 head and Comp cam/lifters. Upgrading the power while it is being rebuilt is cheaper that doing it down the road.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
camshaft , carburator , intake manifold
Intake For a 4.2 and a carb 88YJWranglerBoy YJ Wrangler Technical Forum 17 11-18-2010 11:48 PM
Intake Manifold/Carb?????s Prouzy YJ Wrangler Technical Forum 5 09-19-2008 06:26 PM
Need help! Carb & intake manifold... LLbadboy YJ Wrangler Technical Forum 4 01-28-2008 09:48 AM
best off road intake /carb 401 eche981 YJ Wrangler Technical Forum 6 09-28-2007 09:40 AM
cool air intake for carb? dinger YJ Wrangler Technical Forum 5 09-04-2006 08:39 PM
