Intake Question - JeepForum.com
post #1 of 7 Old 03-26-2002, 04:28 PM Thread Starter
jfarrell
Intake Question
If I put a later model cone style K&N filter setup on my 90 YJ 2.5L with TBI will it cause it to run lean? Just wondering, looking for some more umh as all the 4 bangers are!
jfarrell is offline
post #2 of 7 Old 03-26-2002, 05:22 PM
Atropine
Atropine's Avatar
It shouldn't run lean it will get more air. If you need more umph for your 2.5L go here
<a href="http://homepage.mac.com/jyokomura/tech/throttlebody01/index.html" target="_blank">http://homepage.mac.com/jyokomura/tech/throttlebody01/index.html</a>
I have some 4.0 TB's here for sale, i'm asking $75 for them shipped.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 7 Old 03-26-2002, 10:35 PM Thread Starter
jfarrell
Thanks for the response! My only concern is that it is a Throttle Body Injected engine and that the fuel injector is also inside of the throttle body. I know that 89 and 90's were made this way, changed to port injection in '91. I just wanted to make sure that this mod wouldn't cause the mixture to run off because of the fact that its getting more air. I know the fuel injector pulses in response to the position of the TPS that's why I was concerned that the engine might run in a lean condition. Has anyone done any mods with the TBI 4 bangers, anyone else curious? I wish that I would have found a 91, it would make this mod so much easier!
jfarrell is offline
post #4 of 7 Old 03-27-2002, 10:25 AM
Atropine
Atropine's Avatar
I totally forgot about that the 90's have TBI (the 3 bolt as opposed to the 4 bolt ones on MPFI) The ones I have are all for MPFI...
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #5 of 7 Old 03-28-2002, 09:31 PM
PoorFool
Hey, I have a 4.0 liter TBI throttle body from an 87-90 Cherokee. I mistakenly bought it to put on my '94 not realizing there was a difference. It's just sitting on a shelf gathering dust. It doesn't have any sensors, and I'm not sure if the injector is the same but you could find out from a dealer. I just want at least some of my $$ back out of it. Find out if it will work then email me if you want it. I'll sell it for $20 plus shipping from 64114. I also get cheap shipping through work. Same goes for anyone else needing a TBI throttle body.
Thanks,
Tommy
tgraves01@msn.com
Turbocharged 4.0, 35" Kevlars, 33 spline Detroit D44, 4.88s, heavy foot.
PoorFool is offline
post #6 of 7 Old 03-29-2002, 10:22 AM
Atropine
Atropine's Avatar
Click the link on my sig for more 4 banger stuff!
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #7 of 7 Old 03-29-2002, 12:44 PM
4wheeler4CJ
4wheeler4CJ's Avatar
The engine's computer should re-adjust when it senses more air intake, shouldn't it? I would say it will adjust the fuel to make the right mix. Shouldn't be a problem.
4wheeler4CJ is offline
intake question DirtyJeep95 YJ Wrangler Technical Forum 2 02-25-2008 11:06 PM
Little Intake question ChrisYJ - Italy YJ Wrangler Technical Forum 9 08-26-2007 11:05 AM
Air intake question GreekGhost TJ Wrangler Technical Forum 17 04-19-2007 11:32 PM
Air Intake Question TJnTN TJ Wrangler Technical Forum 3 11-01-2004 04:42 PM
Air intake question FireFoxDT TJ Wrangler Technical Forum 19 10-29-2004 11:04 AM
