intake on an 89 YJ - JeepForum.com
post #1 of 8 Old 04-03-2002, 02:52 PM Thread Starter
flashJP
intake on an 89 YJ
ive got an '89 yj and want to put in a metal pipe and cone filter,k&n or knock-off..doesnt matter to me...my question is....under the air filter box assembly there is another hose coming out goin towards the center of the engine...what is that? can i just take it out? basically i just want to pull all that out...and put in a straight pipe with a cone filter...what if any little hoses do i have to worry about?????
thanks a lot, i really appreciate anything u can tell me
89 4cyl fuel injected
1989 Wrangler YJ Red
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
NEW: distributor cap,rotor,spark plugs,wires,fuel filter,ccv&pcv, steelhorse console...
flashJP is offline
post #2 of 8 Old 04-03-2002, 03:08 PM
Bigrubberjeep
Hey nice ride! Exacly like mine. he he
Your idea is good, hoever i do recomend very strongly that you atach the 2 little hoses to the new tube you are thinking of using. Just drill 2 holes in it the size of the tubing and then cylicone them so they are air tight because after all they are leading to the engine and if you get debris intheir it could mess it upin the long or maybe short run. What I did was just buy a cone filter from autozone, I pulled the air tube from the stock airbox and hooked it up to the new cone. This way your little hoses canstill suck in air from their factory box. Just tape off or cover somehow the hole left by the air tube (the top of the air box) soyou dont get debris in their either, i just used tape and covered mine. Now your wondering well ware the heck do I place the cone? well being that the factory hose is flexible I just tucked it under the long support bar and it is pointing to the left sitting on top of the fenderwell. Check out my website under What's new. You will see a very bad picture of what I mean. Oh yeah, and yes I did notice and improvement
To Jeep or not to Jeep, what's the question?
Bigrubberjeep is offline
post #3 of 8 Old 04-03-2002, 07:38 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Or do what Atropine did and what I plan to do. Get a honda civic intake kit (because they are usually in stock at most parts stores) and use that. They are ALOT cheaper than Jeep ones and are basically the same thing with minor modification on the rubber connection to the TB.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #4 of 8 Old 04-03-2002, 09:26 PM Thread Starter
flashJP
thanks for the input, i think im gonna look into that...
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
flashJP is offline
post #5 of 8 Old 04-04-2002, 02:46 PM Thread Starter
flashJP
how do i attach it to the throttle body openeing? what size is it?
4-cyl 2.5 L
AX-5 (5spd)
15x7 OutLaw II
flashJP is offline
post #6 of 8 Old 04-04-2002, 03:05 PM
Bigrubberjeep
Check out this guys mod on the intake. It's in his web page
<a href="http://www.yankeetoys.org/mangler/mods.htm" target="_blank">http://www.yankeetoys.org/mangler/mods.htm</a>
Similar to mine except I left the factory air box on.
post #7 of 8 Old 04-05-2002, 10:05 AM
MusicMaverick
2014 JK Wrangler
Go to a hardware store and try to find the right rubber connection. Probably in the plumbing area
Currently: '14 JKU
post #8 of 8 Old 04-05-2002, 01:53 PM
NOVA Jeeper56
I have one of a eclipse and you must connect both the rubber hosses. One is for the crank case to suck out pressure b/c its not a valve. The second is your evaporation canestor.
'94yj, rancho lift kit, 31x10.50 BFG mud's,intake,exhaust,wheels, warn 6000lb winch,lights,
bumpers/brush guard
(used to be known as BiggMike56)
NOVA Jeeper56 is offline
K&N Cold Air Intake vs AEM Brute Force Intake... anyone help? TJoshX TJ Wrangler Technical Forum 25 06-25-2011 02:19 PM
Best Air Intake 0blcktj6 TJ Wrangler Technical Forum 31 07-22-2008 11:08 PM
Installed 4.0L TB, 62mm Spacer, High Flow Intake, and bored out intake manifold... micfly83 YJ Wrangler Technical Forum 35 08-21-2006 05:32 PM
Oil in TB intake and intake tube?!?! Jeepin J-rod YJ Wrangler Technical Forum 9 05-15-2006 09:12 PM
Intake BDAZCJ5 TJ Wrangler Technical Forum 4 07-29-2005 10:54 PM
