Intake - JeepForum.com
post #1 of 10 Old 09-01-2014, 08:11 PM Thread Starter
jasonjones21
Intake
Hat do you guys think of the Clifford performance 4 bbl intake with a 4 bbl carb how does the 258 run with that setup "any more power ??"
jasonjones21 is offline
post #2 of 10 Old 09-01-2014, 08:36 PM
mrmud4x4
I have the Motorcraft 4 barrel carb....I put it on the stock intake. It's the biggest the jeep can handle...about 350 cfm. I did not want to change the intake mainly because I did not want to put exhaust headers on it.
If you do the intake and headers....probably be great.
It runs way stronger...And my main reason was no stalling on an incline, especially when I need to hit it...
I did the nutter bypass.
It does run a little rich....No smog check here in NC.
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #3 of 10 Old 09-01-2014, 09:16 PM
mike134
I love my 89 4.2L MPFI!! It looks like the prices are getting out of control though
mike134 is online now
post #4 of 10 Old 09-01-2014, 09:28 PM
chris142
imo a 4bbl is overkill for a 258. holley makes a 350cfm 2 bbl thats plenty.thats my take on it anyway
chris142 is offline
post #5 of 10 Old 09-01-2014, 09:33 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Same here. I run a weber 38/38 I've read it's a 390cfm carb. It sucks in more air then my 258 can push out with 2.5" exhaust.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 10 Old 09-01-2014, 09:53 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
I had the Offenhauser intake and a Holley 390 with a cam and header. (my old CJ7)
The 390 was not too big for a cam and header.
Let's just say it woke up. It would smoke the tire down the block. I said tire because it had a rear open diff.
4 barrels get good fuel mileage if you can keep your foot out of it. I couldn't.
"Under certain circumstances, profanity provides a relief denied even to prayer." - Mark Twain
Chrisnvegas is online now
post #7 of 10 Old 09-02-2014, 09:38 AM Thread Starter
jasonjones21
Will a Clifford performance 6=8 intake/header/weber pass smog in Denver?
post #8 of 10 Old 09-02-2014, 10:08 AM
Chrisnvegas
INFIDEL
Denver is as strict as California. No, it will not pass.
If you are moving there and aren't dead set on living in Denver proper, you can move to the outskirts where there is no testing. Places like Evergreen, Conifer, Idaho Springs.
They are 30 minutes outside of Denver. (Those are foothills areas)
Just make sure you are in Clear Creek County, Parts of Weld County ect.
I prefer the more rural areas anyway.
Only other thing you can do is fuel injection.
post #9 of 10 Old 09-02-2014, 10:20 AM
roadyrob
1987 YJ Wrangler
I also have the offy manifold and holley 390, its a great setup but you do need to run a complete package to get its full potential, ignition, cam and exhaust. BUT, if you have to pass emissions you will do better running fuel injection. A good carb man with an EGA could set the carb to pass but there aren't many carb men left.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #10 of 10 Old 09-02-2014, 10:35 AM
superj
the four barrel was a great upgrade on my 87 wrangler. got better gas mileage and took off quicker. the intake made it a lot easier to fit the four barrel and made it look cleaner. i had the offenhauser intake instead of the clifford.
i had the weber 34 carb first. junk
then a motorcraft 2100. mmmeh, it was ok.
then a motorcraft 2150. same thing, meh.
then a holley two barrel from a 68 dodge car, it was freaking badass!!
then a holley 450 four barrel on offenhauser intake. improved gas mileage and performance and never gave me a bit of trouble.
but that two barrel holley from that old dodge car was the best off all the different carbs i tried.
the four barrel got hte best gas mileage though because the two primary barrels are smaller then what comes on a two barrel carb.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
