INSTRUMENT PANEL LIGHTS -- off - JeepForum.com
post #1 of 10 Old 04-15-2013, 05:24 PM Thread Starter
RainShadow
Howdy folks: My complete instrument panel went out the other night while driving home from camping.
Put in a new fuse in the panel slot and still no lights on the panel -- what gives ???
Everything else works -- Radio, Door light, headlights, etc. etc.
I even checked the new fuse with tester before I put it in ...
thanks, Randy 1995 YJ 4 banger , manual trans.
RainShadow is offline
post #2 of 10 Old 04-15-2013, 05:40 PM
Mark05059
move the dimmer switch for the dash lights up and down? They go bad quite often
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 10 Old 04-15-2013, 06:24 PM
Que89YJ
Good advice.
Que89YJ is offline
post #4 of 10 Old 04-16-2013, 10:12 AM
gtg413i
2003 WJ
X2. Replace switch.
Brian's Black Betty Build:
gtg413i is offline
post #5 of 10 Old 04-16-2013, 01:48 PM Thread Starter
RainShadow
Light Panel , cont
I tried the dimmer switch first and that was not it. Sometimes it will move
when I clean the interior when I get back from camping; but this happened before I did that.
I wll check into the actual switch -- hopefully it will not run me $100 !!!
I have not found a good Jeep "junkyard" in San Diego County yet......
Maybe Collins Brothers ???
Tx, Randy
post #6 of 10 Old 04-16-2013, 02:07 PM
Que89YJ
jumper power across the connector for the dimmer and see if the light comes on.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 10 Old 04-17-2013, 01:06 AM
gtg413i
2003 WJ
Tx, Randy
911jeep dismantlers is at the border, otherwise there are lots of dismantlers by mexico. Ebay has these switches used for about $20.
gtg413i is offline
post #8 of 10 Old 04-17-2013, 07:28 AM
Que89YJ
They are under $30 new at most of the parts store. Any chance the new fuse popped when you put it in?
Que89YJ is offline
post #9 of 10 Old 04-17-2013, 08:28 AM
Deserteagle2
That happened to me, it was the dimmer switch. It is actually quite easy to take it apart and clean up the inside, as it is probably very corroded, and they don't actually break or go bad that often. After you get the switch out, there are two clips that hold the heatsink on it, just pry the clips off. Then remove the little circuit board looking contactor. Clean up the copper contacts, put some dielectric grease on it, and reassemble it. And its actually called a rheostat dimmer I believe.
Deserteagle2 is offline
post #10 of 10 Old 04-18-2013, 09:28 AM Thread Starter
RainShadow
Instrument Panel Lights ....
Well --- it actually was the "dimmer" switch after all !!! I messed with it again
the other night and got a quick light up on the panel. I took it apart and cleaned it up -- I need to get that grease though.
I am finding a lot of electrical contacts getting a little sticky.
thanks guys for your help, Randy from Oceanside
