Instrument panel - JeepForum.com
post #1 of 9 Old 09-01-2013, 11:14 AM Thread Starter
jgrindle13
Instrument panel
Was changing out my serpentine belt and after heading back to the parts store, I noticed that nothing is working. No speedo, no tach, nothing. The only one semi working is my fuel gauge. However it shows that I have a full tank but I know that's not the case. Any help would be greatly appreciated.
jgrindle13 is offline
post #2 of 9 Old 09-01-2013, 12:30 PM
jason280
Sounds like you blew the 15a fuse that controls the dash/instrument cluster. I *think* its #9 in the fuse box, but can't remember for sure. Go through your fuses, I'm almost certain that's your issue.
None
jason280 is offline
post #3 of 9 Old 09-01-2013, 12:51 PM Thread Starter
jgrindle13
All fuses are good
post #4 of 9 Old 09-01-2013, 01:56 PM
jason280
What about the rest of your electrical, everything working correctly? Lights, vent fan, etc?
None
jason280 is offline
post #5 of 9 Old 09-01-2013, 02:07 PM Thread Starter
jgrindle13
All good
post #6 of 9 Old 09-01-2013, 02:17 PM Thread Starter
jgrindle13
Well, the lights and everything else works, still not the gauges
post #7 of 9 Old 09-01-2013, 05:11 PM
Que89YJ
You need to check the 12 volts at the fuse and at the guage connector. Do a forum search if you need a diagram.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 9 Old 09-02-2013, 07:14 PM Thread Starter
jgrindle13
Looks like I had a bad fuse. Fixed it then it blew again 10 min later while driving. Any thoughts?
post #9 of 9 Old 09-02-2013, 07:35 PM
Que89YJ
You need to pull the cluster and check the wiring and the cluster for corrosion.
Fault codes:
No Start:
Que89YJ is offline
