-   -   Instrument panel (http://www.jeepforum.com/forum/f12/instrument-panel-1569876/)
jgrindle13 09-01-2013 11:14 AM
Instrument panel
Was changing out my serpentine belt and after heading back to the parts store, I noticed that nothing is working. No speedo, no tach, nothing. The only one semi working is my fuel gauge. However it shows that I have a full tank but I know that's not the case. Any help would be greatly appreciated.
jason280 09-01-2013 12:30 PM
Sounds like you blew the 15a fuse that controls the dash/instrument cluster. I *think* its #9 in the fuse box, but can't remember for sure. Go through your fuses, I'm almost certain that's your issue.
jgrindle13 09-01-2013 12:51 PM
All fuses are good
jason280 09-01-2013 01:56 PM
What about the rest of your electrical, everything working correctly? Lights, vent fan, etc?
jgrindle13 09-01-2013 02:07 PM
All good
jgrindle13 09-01-2013 02:17 PM
Well, the lights and everything else works, still not the gauges
Que89YJ 09-01-2013 05:11 PM
You need to check the 12 volts at the fuse and at the guage connector. Do a forum search if you need a diagram.
jgrindle13 09-02-2013 07:14 PM
Looks like I had a bad fuse. Fixed it then it blew again 10 min later while driving. Any thoughts?
Que89YJ 09-02-2013 07:35 PM
You need to pull the cluster and check the wiring and the cluster for corrosion.
The time now is 09:15 PM.
