Instrument lights don't work! help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Instrument lights don't work! help!
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 07-10-2010, 11:48 PM   #1
94YJTech
Alright, so my dashboard lights don't work. the switch still turns on my headlights and the roller still turns on the lights by my doors.
I don't know whats going on.
Anyone know anything about this?
any help much appreaciated!
94YJTech is offline   Reply With Quote Quick reply to this message
Unread 07-10-2010, 11:55 PM   #2
LeJerk
2009 JK Wrangler
Are the bulbs burnt out? Did they work before and all of a sudden stop?
LeJerk is offline   Reply With Quote Quick reply to this message
Unread 07-10-2010, 11:58 PM   #3
94YJTech
Well I accidently left my dome lights on over night and the next morning the jeep started perfectly, but the dashlights wouldn't work.
I haven't checked the bulbs, I looked for them but I didn't find them.
Where are the bulbs located?
Unread 07-11-2010, 12:59 AM   #4
LeJerk
2009 JK Wrangler
3 screws above and 3 below the cluster. The light behind my gas gauge is out, but I haven't gotten around to replacing it yet so I can't tell you exactly what to look for other than small lightbulb shaped objects
Unread 07-11-2010, 02:52 AM   #5
dtn8tr
Did you check the fuses? Interior lights, dash lights and head lights should all be different fuses.
1997 TJ, 4" ProComp, 33x12.5x15 Firestone Destination MT, JKS Quicker disconnects
sold-1988 YJ, 4.2L, 2.5" OME, .75" boomerangs, 33x12.5x15 Cooper Discoverers, Herc'd,Nuttered, TeamRush'd
2001 WJ stock DD, 4.0l, Select-Trac
Most good stories start out "Y'all ain't gonna believe this ****...."
dtn8tr is offline   Reply With Quote Quick reply to this message
Unread 07-11-2010, 07:06 AM   #6
idaholtby
Check fuse #10 which is a 5amp and is the leftmost fuse on the bottom row in the fusebox below the dash. It is on the output of the dimmer switch going to the dash lights. If this fuse is good and your marker lights are out as well, then check fuse #8 which is a 20amp and is in the middle fuse on the second row from the bottom. If both fuses are good, then your dimmer is likely at fault.
idaholtby is offline   Reply With Quote Quick reply to this message
Unread 07-11-2010, 07:31 AM   #7
MJMPC
Do you have tail lights?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 07-11-2010, 10:00 AM   #8
94YJTech
Alright lejerk thanks.
I haven't checked the fuses yet I'll be doing that today now thanks man.
I do have tail lights and reverse lights.
Unread 07-11-2010, 11:40 AM   #9
94YJTech
That was it, success fuse #10 needed to be changed
Thank you very much idaholtby.
Thanks everyone for their suggestions.
Unread 07-11-2010, 11:42 AM   #10
idaholtby
Thanks for reporting back with the resolution. Glad to hear you got it fixed
Unread 07-11-2010, 12:04 PM   #11
94YJTech
Sometimes You just gotta check the simple things first. Thanks for telling me which fuses, I had no clue about which would be which.
Unread 07-11-2010, 12:15 PM   #12
MJMPC
Now you need to find out why that fuse was blowed.
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
Unread 07-11-2010, 12:50 PM   #13
94YJTech
The fuse wasn't blown it was corroded on the arms. So I think it was just an old fuse that needed to be swaped.
Unread 01-17-2014, 04:58 PM   #14
PharaohMoe
can you show me where fuse that fuse is all my lights/radio dont work and i hope that is the fuse i need to change in order for it to work again
PharaohMoe is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 07:09 PM   #15
kletchworth1
ok so im having a similar problem except this jeep just got running again after about a year only two lights light up on the instrument panel and the others don't
kletchworth1 is offline   Reply With Quote Quick reply to this message
electrical , light , instrument , panel , disply , YJ , wrangler
