Installing weber 34 carb, Fuel pressure reg installed
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Got my eye on you.....
Exactly as it states, recommend me a fuel regulator that will last and is accurate. I have read about getting a mr gasket one from the local parts store but see mixed reviews.
SO, what do you recommend???? -Rusty ![]()
#2 |
I use the Mr.Gasket. Just make sure to put thread sealant on the input and outputs because it will (somewhat obviously) leak. That said, I plan to put on an electric fuel pump sometime and would likely put on a holley regulator at the same time.
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
#3 |
Buy a hooly one there like $30 from jeggs, I have a mr gasket one . its not even a year old & its malfunctioning, it stops my fuel flow all together. if I play with the pressure setting it starts working again. so I just orered a holley #510-12-804 & pressure gauge # 55-41040. My buddy runs one on his hot rod and has never had any problems with it. the MR gasket one just seems very CHEAPLY made.
#4 |
x2. I would also like to know... since the PO didn't know anything about carbs and just put the weber on with no regulator.
#5 | |
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#6 |
Yes, I Understand!
Here you go Rusty.
http://www.jegs.com/i/JEGS/555/41040/10002/-1 I use the same regulator and similar type of gauge. Make sure you get the standard regulator (1-4 psi). Weber only needs 2.5-3 psi. Ricky |
#7 | |
#8 |
why do u need the gauge and where does it go... in the cab?
#9 |
I tried one, not sure who makes it, and it wouldn't run when cold. I put it in one night after work when the heep was warm and it seemed to run fine. The next morning when it was cold it started but i got 100 yds down the road and it wouldn't start. Does anyone have experience with their weber jets being too rich????????
#10 | |
http://www.jeepforum.com/forum/f8/weber-34-dgec-carb-too-rich-jets-tune-jeep-4-2-258-a-631105/ /Hijack
#11 | ||
Yes, I Understand!
I have mine on top of my valve cover. |
#12 |
how you adjust it? with a screw driver?
#13 |
Yes, I Understand!
In the last pic you can see the adjustment screw on the regulator.
Just loosen the nut then adjust the screw with an allen key. I believe in is less and out is more. |
#14 |
I've been using my Mr. Gasket one for two years, no problems. But I will say I don't like the hose clamps that come with the kit, use some normal screw-band clamps ones like on the radiator hoses.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped. Daily Driver since April 23rd, 2003 Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/ Early YJ Club Member #37 For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite |
#15 |
Somewhat of a departure, but not quite: Do I need a FPR with my MC2100? I'm just running the stock line into the carb with no regulator, and am still using the factory return line.
Thanks for any input. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
