Installing SYE - How much axle shim to use? (4" lift) - JeepForum.com
post #1 of 9 Old 09-10-2007, 09:44 PM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
So just trying to sort out if I can shim my axle or if I need to re-weld the perches in the right spot.
I have a 93 YJ with 3.5" BDS springs. Running "fronts" on both front and back. Xfer case in stock location. Standard SYE. 1" MML. Stock shackles in back, but 1" longer in front.
I'll end up just installing the SYE and seeing what my angles are, but I was curious was others found out. It would be great if I could get away with a shim and no welding.
Mark.
Mark_ZZ3 is offline
post #2 of 9 Old 09-10-2007, 10:13 PM
jeep795
if anything throw on longer shackles in the back as well, and then see how much you need to shim
jeep795 is offline
post #3 of 9 Old 09-10-2007, 10:17 PM
flysyj
flysyj's Avatar
the proper angle on an sye..is the pinion yoke..pointing almost straight at the t-case yoke, a few degrees low is prefered, becuse of wrap at acceleration..i have an re-4" with an advance adaptors sye-(not the super short type) i kept in my 6* shim and the t-case/skid plate 1" drop in, to get the proper angle-no vibes~fly
flysyj is offline
post #4 of 9 Old 09-10-2007, 10:33 PM
wranglerswrock
i have a 3.5 black diamond, and although i figured a major benefit to the sye was gonna be the tummy tuck, i had to do what the guy above said exactly. 6* shims with a transfer case drop got it to where it needed to be. I am puttin on a 1" body lift, and 1" mml... i am hoping that will bring it closer, so i can at least have less of a transfer case drop, or in a perfect world, none at all =)
hope this helps too
and btw, every jeep is different... like, for real. so dont be surprised if you are just good to go striaght up liek you are, or if you have to reweld the perches. its a 50/50 shot
wranglerswrock is offline
post #5 of 9 Old 09-10-2007, 10:52 PM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
Well geez ... I did not think about leaving the transfer case drop in. It's only a 1" ... maybe that is the interium solution?
The real catch is I have a D44 in the works and don't want to spend a ton of cash on the D35, but the vibrations are bad with my new springs. So I figured the SYE would need to go in.
Hmm ... this does offer some new ideas ...
Mark.
Mark_ZZ3 is offline
post #6 of 9 Old 09-11-2007, 12:25 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
8 shims did it for me for 4" springs and 1" shackles with no T-case drop.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 9 Old 09-11-2007, 07:37 AM
bamato
bamato's Avatar
Like sentinal said. I have 3.5"s of lift and run 1 inch shackle. 8° shims worked perfect for me. Best way to do it is to go out and buy a cheap angle finder for about 10 bucks, measure the pinion angle, then measure the driveshaft angle. They should be identical, assuming you have a cv shaft, and are still running the dana35. If you are running an axle with any sort of offset, different degrees are necessary.
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #8 of 9 Old 09-11-2007, 11:24 AM
yjbubba
I put an RE 4.5 lift and AA SYE on my 89 and without dropping the skid plate I needed 12* of shim, I opted to fab up new perches and weld them on.
yjbubba is offline
post #9 of 9 Old 09-11-2007, 11:30 PM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
That is sort of where I was thinking it was going to be. I'm going to have to just install the SYE and measure it up. No other way to do it ... just add some time to the project.
Great responses. Many thanks.
Mark.
Mark_ZZ3 is offline
Axle shim flame0086 YJ Wrangler Technical Forum 16 10-06-2009 12:53 AM
installing 1" body lift and 1" motor lift is there anything i should know about them? crawlr TJ Wrangler Technical Forum 16 08-21-2008 06:42 PM
Rear axle shim dankeenan YJ Wrangler Technical Forum 1 11-15-2007 06:35 AM
Is there any disadvantage to installing a 1" body lift and 1"M.O.R.E motor mount lift DLoweinc TJ Wrangler Technical Forum 10 01-17-2003 06:37 PM
