Installing suspension seats and... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Installing suspension seats and...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 12-16-2014, 03:41 PM   #1
tookie
harnesses, tying them into the frame. This will cause me to lose the
factory bases on the seats, so no tilt forward for rear seat access.
Thinking about doing this... Frame is going to be square tube (in blue)
angle iron on 2" by 3/8" thick flat bar, that the seat will be mounted to.
Then four square hitch pins to quickly remove seat.
Anyone got a good reason this would be unwise?
tookie is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 04:25 PM   #2
timatoe
Why not just make it pivot to the front if you're concerned with rear access?
I built solid mounts for my seats, they don't pivot etc. but I took the rear seats out anyhow.
timatoe is online now   Reply With Quote Quick reply to this message
Unread 12-16-2014, 04:36 PM   #3
tookie
I thought of that, but just pivoting, without also moving forward,
would not really give any clearance.
Unread 12-16-2014, 05:15 PM   #4
boduke5051
I wonder if it would be possible to fab the hinge peices from the original bases into the new suspension bases? Would probably be a nightmare to do, and anybody's guess at the strength of it if an accident were to occur.
If you can't be good, be good at it! >:-D
http://www.jeepforum.com/forum/f286/hound-2833082/
boduke5051 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 05:23 PM   #5
Luuca
Professional Novice
Luuca's Avatar
You are betting your noggin on a $1.25 bar pin. well, ok, four of them. If they are grade 8 hardened, it's a decent bet. That said, we are driving YJs...
91 YJ "Alice" 2.5L AX5 D30/35 -Busted Knuckles Yellow Jeep Club #91
05 LJ Rubicon "Ghost" 4" RE Lift 1" BL 33s
Luuca is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 06:31 PM   #6
ssyj94
It wont be as quick as you think. How are you planning to quick disco the harnesses so you can aactually remove the seat? You could just put the seats on sliders to gain a couple inches of forward movement.
Link locked and ready to rock
Http://www.jeepforum.com/forum/f12/y...lovers-1121183
ssyj94 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 07:12 PM   #7
Norcal_chris
Norcal_chris's Avatar
^this
It is quite the ordeal to pull seats and harnesses. Put them on sliders or buy some that recline forward. No real other way around it
2.5/doubler,D60/14bff,108WB,H1s,39.5IROKS 3link front w/ 14in Kings/4 link rear w/ Tj coils
Norcal_chris is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 08:38 PM   #8
ROWA
ROWA's Avatar
How are you anchoring the harness shoulder straps?
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 09:44 PM   #9
tookie
Yes, I realized this after I posted... minor adjustment to the design will
let me slide it forward, after removing 4 pins, but I will not be able to
fully remove due to harness thru seat ... pins are 3'8", hardened,
should hold up if I go this route.
Unread 12-16-2014, 09:50 PM   #10
TSEJEEPERS
You do know the harness needs to be fastened to a bar that is shoulder height right?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 09:50 PM   #11
tookie
Using these Corbeau retractors, anchoring either at rear plate of
cage, or welding a mounting tab on the cage at the rear, so the
retractor will be about even with a rear passengers elbow height.
Unread 12-16-2014, 09:54 PM   #12
TSEJEEPERS
Please read through this.
http://www.pirate4x4.com/tech/billav...rness_install/
The shoulder straps should be mounted at shoulder height.
Unread 12-16-2014, 10:18 PM   #13
tookie
They pretty much will be
Unread 12-16-2014, 10:20 PM   #14
JonCorwin
Tookie, how big are the pins you're using? 3'8" seems a bit excessive.
JonCorwin is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 10:28 PM   #15
Norcal_chris
This has bad news written all over it.
