Installing Shackles? - JeepForum.com
post #1 of 4 Old 07-31-2002, 01:25 PM Thread Starter
spgsig
I'm installing 2in lift shackles this weekend and was wondering if there is any tricks or procedures I should follow to make the job go a little easier?
93 yj
31 BFGs
K&N filter
Borla Header and high flow exhaust
more to come....
spgsig is offline
post #2 of 4 Old 07-31-2002, 01:32 PM Thread Starter
spgsig
BTW
I also got new poly bushings.
93 yj
31 BFGs
K&N filter
more to come....
spgsig is offline
post #3 of 4 Old 07-31-2002, 01:59 PM
soccer_Steven
I just put 1 1/4 shackles on my yj. I found that the front is easy if you have 2 people, a stand jack and a normal jack. I had to wedge the stock jack between the leafs and the upper part (lower part of body). This made the front easy. But the back is a whole-nother story. I had a problem with the gas tank. I had tol bang, break, then finally cut the old bolts off. After I got the old bolts off it was pretty much straight forward. If you need any other info just PM me.
soccer_Steven is offline
post #4 of 4 Old 07-31-2002, 03:14 PM
moabster
moabster's Avatar
2011 WK
When replacing the shackles on our 93 YJ I found that after removing the nut and bolt you need to remove the metal bushing in the middle of the rubber bushings before you try to remove the rubber bushings. I used a punch and hammer to remove the metal bushing.
On the rear, I could not remove the bolt (gas tank in the way) until the rubber bushing was removed. To do this I first removed the spring end of the shackle. Then I removed the nut from the top of the shackle and the outside half of the shackle. Then I used a punch to push the bolt through far enough so that I could also push the metal bushing through. Next I removed the outside half of the rubber bushing with a pair of pliers. Then used the punch to force out the gas tank half of the rubber bushing. With the bushing out there was enough room to wiggle the bolt free without cutting it.
Overall, this was a pretty easy job.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
Installing boom shackles? brinoff YJ Wrangler Technical Forum 28 10-17-2008 07:39 PM
Installing MORE boomerang shackles flame0086 YJ Wrangler Technical Forum 9 03-25-2008 03:31 PM
Installing new shackles, question... Jesta YJ Wrangler Technical Forum 0 10-21-2006 04:42 PM
installing lift shackles? iwishihad1 YJ Wrangler Technical Forum 14 10-21-2006 12:08 PM
installing lift shackles bono426 YJ Wrangler Technical Forum 7 06-30-2005 03:08 PM
