-   -   Installing Polk db460 Speakers - write up (http://www.jeepforum.com/forum/f12/installing-polk-db460-speakers-write-up-554831/)
cushtech 05-05-2008 08:57 PM
Since there have been a few recent posts asking about installing speakers I thought I'd write up my recent install. It should answer some questions and save people some time and money.
There are a couple of options for new 4x6" speakers. I decided on a pair of Polk db460s I found on eBay. They got some decent reviews and they are "marine certified" so water damage isn't a problem. When I tried to install them I found out they have the same problems a lot of speakers seem to have. They didn't have the right mounting holes and the tweeters stick out too far to flush mount them. Fixing things is pretty cheap and easy.
Here's a quick writeup of how to modify and install the Polk db460s but it should be useable for other speakers with the same problem.
Remove the stock speakers from the dash.
I ended up folding the windshield and pulling the dash out. There are lots of threads about this. Here's a good webpage describing how to do it.
http://www.carstereohelp.com/stereor...nglerFSpk1.htm
Remove the plastic rings from the old speakers.
Use a razor or xacto knife to separate the ring from the speaker. I also used a heat gun to soften up the adhesive. Be careful to not to damage the rings or melt them if you use a heat gun, you're going to use these as spacer rings. Clean off all the junk from them.
http://www.gearheadlabs.com/images/jeep1/pic1.jpg
http://www.gearheadlabs.com/images/jeep1/ring.jpg
Drill New Mounting Holes.
Put the old speaker face to face on top of the new Polk. The Polk db460 almost fits inside the stock factory speaker. Use the old speaker as a guide mark the hole location on the new speakers with a marker or pencil. Separate the speakers, center punch where the marks are and drill the new holes. I used a slightly larger drill than what fit through the mounting holes on the stock speaker.
http://www.gearheadlabs.com/images/jeep1//drill1.jpg
http://www.gearheadlabs.com/images/jeep1/newholes.jpg
Mount the spacer rings on the new speakers.
Using a hot glue gun, contact cement or other general adhesive attach the spacer rings from the old speakers to the new speakers. Be careful not to get glue on the rubber surrounds.
I put 4 drops of hot glue on the cardboard mounting ring. A quick alignment and some slight downward pressure and the spacer rings were mounted.
http://www.gearheadlabs.com/images/jeep1/plusring.jpg
Add the speaker cloth.
Using a hot glue gun glue some speaker cloth to the spacer ring. Glue one side, let it set then put some glue down on the other side and stretch the fabric before attaching it.
This is an optional step. I had some black cloth hanging around and wanted to cover up the shiny cones of the Polks.
http://www.gearheadlabs.com/images/jeep1/withcloth.jpg
Mount the speakers to the dash.
Wire up the speaker. (I used a Metra factory wiring adapter from Circuit City.)
Put 3/8" nylon spacers on the mounting bolts.
Slide the speaker on the bolts. Make sure the wiring side is down so the terminals are accessible if you need to get to them later.
Add some lock washers and 8-32 nuts. I recommend not reusing the factory nuts. For those of you who don't fold the windshield wing nuts work well.
You don't want to have to open things up again just to tighten some nuts so use some thread locker (Loctite)
Tighten up the nuts.
Reassemble your dash and windshield.
http://www.gearheadlabs.com/images/jeep1/dash3.jpg
With the spacer ring and the grill cloth the Polk db460 tweeter sticks out just a little too far. If you tighten things up the tweeter will push the metal grill out just a bit. If this bothers you can add some washers next to the nylon spacers on the bolts.
http://www.gearheadlabs.com/images/jeep1/dash4.jpg
Total time to do this once the windshield was dropped was under an hour. I got the spacers, the #8 lock washers and 8-32 nuts from my local True Value hardware store. The wiring adapter is a Metra 72-1002 Speaker Harness. (Circuit City or partsexpress.com) Using one means you don't have to cut/solder/crimp anything to use the factory wiring. The db460s have been replaced by the db461s. I'm not sure the tweeter sticks out the same amount. If it's more you can always pull the grill off the tweeter.
http://www.gearheadlabs.com/images/jeep1/dash5.jpg
While the windshield was down I ran some wires for some future dash mounted tweeters.
That's it. Pretty fast and not that complicated. The speakers sound pretty good for what they are. I'll be adding some dash mounted tweeters later to improve the sound.
djfred 05-05-2008 09:18 PM
Nice Write-up
Burnerman 05-05-2008 09:29 PM
I threw Pioneer 4x6's in the dash. My spacers were toast on the stockers and I mounted them tight to the dash. I had to cut out the centers of the dash grille so the tweeter wires wouldn't short out. That's a nice writeup and wish I'd read it before I did mine.
cushtech 05-06-2008 09:40 AM
Thanks for the no-click help. :thumbsup: I'll be adding those tweeters, xover and amps in the next couple weeks if it doesn't rain.
denalione 05-06-2008 09:46 AM
Thanks for the write up. I'll be putting in my new Polk speakers on Friday.
djfred 05-06-2008 10:15 AM
no prob cushtech, cant wait for the rest of the write up keep up the good work.
Also post your work in the Write-Up Section.
YJ_95 05-06-2008 11:02 PM
I have polk 4 inch round speakers in my sound bar and i would highly recommend these speakers to anyone. They get plenty of volume if you dont want to hear the road and i dont have to worry about if its gunna rain with the soft top off.
supersixfour 05-06-2008 11:40 PM
I don't mean to hijack this thread but I have a pair of Polk DB560 lying around...as anyone found a good spot for these or does anyone have ideas?
Thanks
Slapahoe 10-17-2008 11:06 AM
Back from the dead, but I thought I would add to this.
I bought an older model of Polk speakers that are just like these 3 years ago.
Within a year, the elements detroyed the rubber at the top of the cone of the speaker. First they dried out, then they cracked, and now they look like I listen to death metal 23 hours a day cranked to the highest setting. :D
How are yours holding up thus far cushtech?
BumbleBee90 11-08-2008 07:09 AM
The new Polk DB series are the first auto speakers that have come out dual rated...both for auto and marine certified. Although the older ones had a poly cone and rubber surround, they were not made to handle the sun and moisture. Try one of the new ones. Much better.
Shenandoah 11-08-2008 08:09 AM
I soldered the connections to my speakers when they were replaced. I ran A 8 inch piece of wire from the speakers and then attached connectors. That way I could ensure the if the connectors came unattached I could easily get to them. Trying to reattach a connector to the speaker can be time consuming.
88TNSahara 11-08-2008 01:52 PM
I just wanted to add to this great writeup. I used the DB461P Polks (plate speakers) instead of the standard
DB460's. I had some spare nylon tubing from a brake bleeding kit lying around. I used a razor blade to cut it into pieces to use as spacers. Also, my Polks didn't come with new nuts and washers; they came with screws and tapped plates. It was a good thing I had some spare washers and nylock nuts in the garage. IMHO, the Polk DB series speakers sound better than any other speaker in the same range, plus they are marine certified!
ufatbastehd 11-08-2008 02:39 PM
I read this write up got inspired and got the DB461Ps too
I used some nylon washers I found in my local hardware store as spacers. Much better sound then the stock speakers.
YJake 02-07-2009 06:58 AM
My driver side dash speaker has been dead since I got the vehicle and that gives em an excuse to upgrade both dash speakers:thumbsup:
I guess I'll give those DB461P Polks a try.
ZeroGravity 02-07-2009 07:47 AM
Why is your jeep not all rusty?
Nice write up.
The time now is 10:52 AM.
