Installing Nerf Step Bars - JeepForum.com
post #1 of 11 Old 05-31-2006, 04:06 PM Thread Starter
sc1972
I searched, but didn't find anything I could really understand. Does anyone know where there might be a write-up on how to install Nerf step bars on a Wrangler? I need instructions that are pretty simple. I'm very dangerous around tools; so dangerous in fact that my girlfriend usually hides them from me.
I assume they just bolt onto the frame under each doorway, right? Is there a specific measurement I should use to center them? I know you're going to just say "eyeball it" but if you could see all the crooked shelves (even using a level) in our house, you'd see why me eyeballing it is a bad idea.
Do you just drill straight through the frame? What size/kind of bolt should be used? I bought the bars used off of a guy on craigslist, and they didn't come with any mounting hardware. Obviously I don't want to jack up the frame by drilling in the wrong place, or having to drill multiple times because I screwed the first ones up.
So a simple write-up, hopefully with pictures and words with less than 3 syllables would do me a lot of good. And if you can't bring yourself to do it for me, then do it for my poor Jeep. A few months ago when I was mounting my rear speakers (and making a mess out of it, simple as it is), my Jeep was so ashamed of being owned by me that it went to a divorce lawyer and threatened me with a legal seperation, followed by a divorce, followed by years and years of giant payments for its "pain and suffering".
Help our relationship. Please.
93 YJ. 4cyl. 5 Speed. Bone Stock except for 30" tires. Only 48,000 miles on original engine. Daily driver.
sc1972 is offline
post #2 of 11 Old 05-31-2006, 04:10 PM
jeep_chinto
the nerf bars should come with instructions.. my yj had nerf bars on them and i took them off looks like there was a place from the factory just to bolt them on because there were nuts welded on the inside of the fraim
jeep_chinto is offline
post #3 of 11 Old 05-31-2006, 08:21 PM
RIGSBN8R
I think they might mount one place on the frame and one place on the body. If you can't hold them up and figure out which hole/body mount it is, then I have nothing to say 'cept "I'm sorry.
RIGSBN8R is offline
post #4 of 11 Old 05-31-2006, 08:27 PM
xxxflhrci
xxxflhrci's Avatar
You basically hold them up to the frame and put them where you want them. Do some simple measuring to make sure you get them in the same spot on each side. You install them with some special self tapping bolts. You have to drill a pilot hole that is slightly smaller than the bolt you use, then turn the bolt into the hole. The bolt cuts it's own threads as it goes in. You should be able to find the bolts at any good fastener store.
xxxflhrci is offline
post #5 of 11 Old 05-31-2006, 08:31 PM
YJBlues
YJBlues's Avatar
If you aren't comfortable with just eyeing it up, simply find the center of the nerf bar and mark it with a piece of chalk, find the center of the door opening and mark it with a piece of chalk, line the two chalk marks up and use holes in nerf bar to mark where the bolts need to go.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #6 of 11 Old 06-01-2006, 12:26 AM
Flashfoto
I put Smittybuilt nerf's on my '88. Self-tapping bolt's came with it & the instruction's tell you what size bit to buy.
I found the best way, was to clamp it where you want it. Drill ONE hole at one end & install the bolt. Check your alignment & repeat the process at the other end. Remove the clamps & drill & bolt the rest. This way, there is no chance of the dang thing moving between drill holes. I used my impact wrench to install the bolt's.
I have beat the hell out of the Smittybuilt's & they have held up well.
Flashfoto is offline
post #7 of 11 Old 06-01-2006, 06:45 PM
drexelsteve
i had a nerf football one time, it was pretty cool.
13 Rubi
drexelsteve is offline
post #8 of 11 Old 12-17-2014, 11:32 AM
Leone911
reply to ADVICE on how to
I'm sorry???? Wow you're a lot of help....I'm a 70 year old who does not work on jeeps every day unlike you!!! I still want to put nerf bar side steps on my 98 Wrangler TJ. I have some tools but the advertisement said nothing about requiring some drilling. I was under the impression these were bolt up installation. Thanks anyway, ACE!
Leone911 is offline
post #9 of 11 Old 12-17-2014, 07:58 PM
Mike Romain
Lol, giving someone crap in a 8 year old post in the wrong forum for your Jeep. Great start there Leone....
Mike
Mike Romain is offline
post #10 of 11 Old 12-17-2014, 08:40 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Welcome to the forum, Leone.
You may find some help on this one in the 'TJ' section, there aren't a lot of YJ's with nerf bars that I've seen anyway. You should be able to get installation instructions from a PDF file on the manufacturers website. Smittybilt I presume?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #11 of 11 Old 12-18-2014, 09:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Nope. And it's not going to require drilling since you need to thread some 1/2" self tappers through the frame to secure them. And after that it's best to weld the edges because there isn't enough bite to keep them secure. I don't understand the negativity sometimes.
Anticanman is offline
Will installing Nerf bars promote Rusting where they are attached? 08JeepMan Wrangler General Discussion 1 11-30-2008 02:51 PM
Installing new nerf bars Snackmaster TJ Wrangler Technical Forum 18 03-24-2007 10:19 AM
Nerf/Step Bars jeepguy121 TJ Wrangler Technical Forum 9 03-25-2006 03:16 PM
Nerf/Step self install? FmrVette TJ Wrangler Technical Forum 32 10-27-2005 11:28 AM
OR_FAB rock slider step bars -Flip mount-able? (for step? BNovak TJ Wrangler Technical Forum 0 07-17-2004 04:54 PM
