Quantcast installing kc lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > installing kc lights
Old 02-12-2009, 06:34 PM   #1
mattyfly42
i jusy bought some new kc lights for the front bumper. my question is this do i have to rewire the new lights or can i some how attach them to the wireing harness for the old stock driving lights. and if i i can how would i do so?
mattyfly42 is offline   Reply With Quote
Old 02-12-2009, 06:36 PM   #2
ImpactFabWorks
i was going to tie mine into the driving lights but I didnt want them on everytime I had the headlights on so I ran a seperate switch for both my uppers on the windshield and lowers on the bumper
ImpactFabWorks is offline   Reply With Quote
Old 02-12-2009, 06:37 PM   #3
MAX_Xj
MAX_Xj's Avatar
when i wired mine i hard wired them to the battery so i could use them when the heep wasnt running. but there is a way to wire them into the switch so they can only go on when your lights are on but i dont know how
1998 4dr XJ
MAX_Xj is offline   Reply With Quote
Old 02-12-2009, 06:40 PM   #4
BuffaloYJ
I tapped a lead going to a running lamp, ran that to my driving light switch, then to the relay. That way, even if the switch for my driving lamps is on, they'll only get juice if the parking lamps are on as well. Hope that makes sense.
________________________________________
'94 4.0, AX-15
2.5" suspension lift, 1" shackle lift, K&N FIPK w/ AEM Dryflow, APN header, Smittybilt Front, Olympic Rear w/ carrier, Poison Spyder Corners
Buffalo born and bred, now in CA.
BuffaloYJ is offline   Reply With Quote
Old 02-12-2009, 09:38 PM   #5
mattyfly42
can the wires from the kc lights be spliced with the driving lights so i dont have to run any more wires? then when i turn the switch for the driving lights the kc lights come on, i s that possible?
P.S. how do you put pics on here?
Old 02-12-2009, 09:41 PM   #6
4U2NV
YOu would more than likely need a relay in between...
"A Boss says GO... A Leader says LET'S GO"
4U2NV is offline   Reply With Quote
Old 02-12-2009, 10:03 PM   #7
dodger889
lost in the woods
dodger889's Avatar
Here is what I would do is run a 12 ga wire to each one to a relay that will handle the amps of them combined.
100 watt should be about 10 amps for both, 130 will be about 15 amps and 150 watts should be about 20 amps. To the relay use piece of 10 ga wire for the power lead with a fuse. To the switch you can use 16 ga wire for that.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Old 02-13-2009, 08:28 PM   #8
mattyfly42
I think i might just run the wires they gave me.
Old 02-14-2009, 10:50 AM   #9
mattyfly42
or what if i install the origanal fog lights and mount the new ones one the windshield. anybody know where i can find llights withe the original wiring plug?
Old 02-14-2009, 11:06 AM   #10
osburn
When you say original fog lights, I assume you have a Sahara? Seems to me that was the only model that came with fog lights from the factory. The only comment I have on that, is that you should be aware that the fog lights do not operate if your brights are on. If they are factory lights, they are wired to turn off if you turn on your brights. May not be an issue to you, but I thought you should be aware. Personally, I'd run new wiring, relay, and switch so it works when you want it to work. If you want to do the wiring job twice, don't install a relay.
There's never enough time to do the job right, but there's always time to do it over.
Matt Osburn
Greengo
Rigrater Score 1032
osburn is offline   Reply With Quote
Old 02-16-2009, 07:27 PM   #11
mattyfly42
my brights dont work anyway. so i found original fog lights on ebay and i am going to mount the kc's on the windshield.
Old 02-16-2009, 07:39 PM   #12
samtye
1987 YJ Wrangler
go to kc's website , they have a diagram of the way they should be installed. i wouldnt tap into the factory wiring because of the amp draw, youll short out your switch. what wattage did you get, i got the 150's so i used a 40 amp relay
http://www.kchilites.com/store/faq.aspx?SID=1&
samtye is offline   Reply With Quote
Glock Forum
