Installing boom shackles? - JeepForum.com
post #1 of 29 Old 10-15-2008, 09:45 PM Thread Starter
brinoff
brinoff's Avatar
Does the axle need to be removed from the springs in order to mount new shackles. I'm just feeling a little lazy......
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline
post #2 of 29 Old 10-15-2008, 09:52 PM
Jeffro06
Jeffro06's Avatar
Just need some jackstands to put the jeep up on, and a floor jack to support the axle. I did one side at a time.
see
Jeffro06 is offline
post #3 of 29 Old 10-15-2008, 10:07 PM
jpfix
a long pipe, a pal with a steady hand and quick reflexes if the pal reaches for a beer when you are shoving in the bolt....
91 YJ Runs 79 CJ5 waiting for winter
YJ - one step away from a CJ = lots of interchangeable parts.
TJ - one step away from a JK = sudden urge to go to the mall
jpfix is offline
post #4 of 29 Old 10-15-2008, 10:15 PM
bigsquat
somebody here recomended just putting a bottle jack between the spring and frame and apply pressure as needed. i havent tride this but if it works it would be the quickest. if it slips tour toast!
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #5 of 29 Old 10-15-2008, 10:18 PM
Barrio
jack it up,remove tire,place stands under frame, let axle drop,remove old, install new, put tire back on, and tighten them up.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #6 of 29 Old 10-16-2008, 06:41 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I did this, and reccomend it... I think I used a sicsor jack from a nissan... worked fine, was quick.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #7 of 29 Old 10-16-2008, 07:24 AM
Bigboyky
I never removed the tire or used a jack between the spring & frame. I raised the jeep supported it with stands, used a big pry bar to pull the spring down. Took maybe an hour for all four corners. make sure you put them on right or it does take twice as long.....
Bigboyky is offline
post #8 of 29 Old 10-16-2008, 01:49 PM
carl6405
I just adjusted my springs up into the next position in my shackle, I did it like BigboyKY, except, i used a sissor jack, the one under the hood of the jeep actualy, instead of a pry bar. makes the job simple. just put your jack between the shackle and the frame of your jeep. that gives you the ability to easily push your leaf spring down or up, which allows you to get the bolt off easy.
carl6405 is offline
post #9 of 29 Old 10-16-2008, 01:51 PM
carl6405
sorry. typo in my last post. "just put your jack between the shackle and the frame of your jeep" I meant, between your leaf spring and the frame of your jeep.
carl6405 is offline
post #10 of 29 Old 10-16-2008, 02:26 PM
jgillespie
Originally Posted by carl6405 View Post
I just adjusted my springs up into the next position in my shackle.
what? next position on the shackle?
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #11 of 29 Old 10-16-2008, 08:46 PM
carl6405
I bought some boomerang shackles and put them on when I had the 4" lift kit on. The shackles have 3 sets of bolt holes in them. I had my leaf springs in the bottom. The body was to high after all that, so I moved the leaf springs up to the middle set of bolt holes, if that makes since.
carl6405 is offline
post #12 of 29 Old 10-16-2008, 08:49 PM
jgillespie
the middle bolt holes are supposed to have a bolt to keep the shackle from bending.
post #13 of 29 Old 10-16-2008, 08:50 PM
Barrio
you can not run that center bolt, i dont.
Barrio is offline
post #14 of 29 Old 10-16-2008, 08:52 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Three sets of holes, like these, or not? In this type of arrangement the middle hole is for bracing purposes, but not intended as a mounting location. Just curious as to what you meant.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #15 of 29 Old 10-16-2008, 08:57 PM
Jeffro06
Jeffro06's Avatar
Nope that doesn't make sense. I bet it looks pretty stupid (sorry to be blunt). It also takes away any advantage of having booms in the first place.
And by saying "The body was too high" what do mean? What problem did the height cause?
I would not recommend doing this...but maybe it's just me.
Jeffro06 is offline
boom shackles Timmy69 YJ Wrangler Technical Forum 5 10-12-2009 02:33 PM
Installing 4" RC Lift and Boom Shackles HanksRide YJ Wrangler Technical Forum 59 05-25-2009 07:53 PM
Boom Shackles markmyst YJ Wrangler Technical Forum 1 12-20-2008 12:40 PM
Boom Shackles, need help JeepsOLot YJ Wrangler Technical Forum 5 07-24-2008 01:35 PM
Boom Shackles iowajeepers YJ Wrangler Technical Forum 8 06-24-2008 10:21 PM
