Installing Bestop fiberglass upper door sliders YJ and TJ - JeepForum.com
post #1 of 7 Old 01-29-2008, 12:45 PM Thread Starter
jeepsurf
I decided to make a write up for installing Bestop fiberglass upper door sliders.
The instructions from bestop are incorrect, so I had to figure it out.
I bought the Bestop 2 pc hard top with upper hard doors. Here's what I have:
Sliders:
Hardware and armrest:
I know, I know..everythings dirty...I use my jeep!
Its easier to install with your doors on your jeep so here we are:
We will be using the three reciever holes for the upper doors:
Here is a close up of the rear reciever:
Use a flat head screwdriver to GENTLY pry the reciever out:
Reciever out:
Next we will need a reciever nut:
Push the reciever nut into the bottom of the reciever. Make sure
the 4 pins on the reciever line up with the 4 hoves in the nut:
Nut on reciever:
Another view, sorry about the blur:
cont-
jeepsurf endorses this post. Most of the time
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread
Nightcrew alive and well, now on VB 4.0
Food mailed 3ooo miles
jeepsurf is offline
post #2 of 7 Old 01-29-2008, 12:57 PM Thread Starter
jeepsurf
Installing Bestop fiberglass upper door sliders YJ and TJ part 2
Next with the nut in the reciever, install assembly back into door:
GENTLY push back into place:
Reciver in:
Now only 5 more to go.
After all the recievers are back in the door, sit the slider on the door:
Notice the 3 bolts - 2 long and 1 short:
The short bolt goes in the forward most reciever by the mirror.
Install all 6 bolts:
In this image, you will see how critical it is to line up the nut with the reciever pin. If you dont, you wont be able to thread the bolt in due to misalignment:
Then the armrest is popped into place and thats it! Secure jeep:
USAF VET
My YJ build thread
jeepsurf is offline
post #3 of 7 Old 11-21-2010, 07:05 PM
94yjsahara
has bestop discontinued hard upper window sliders?
seems like all I can find is soft uppers with glass sliders
94yjsahara is offline
post #4 of 7 Old 11-22-2010, 09:13 AM
BestopTeam
Vendor
BestopTeam's Avatar
2010 JK Wrangler
Upper sliders are still available. Here's the page with part numbers.
Nice write up. What was the incorrect part of the install guide? I've only done this install once, on a TJ. I had trouble getting the receiver nuts on, but otherwise it went straightforward.
BestopTeam is offline
post #5 of 7 Old 12-09-2010, 02:51 PM Thread Starter
jeepsurf
Its been so long, I don't recall exactly. I do think it was something to do with the receiver nuts.
USAF VET
My YJ build thread
jeepsurf is offline
post #6 of 7 Old 08-02-2015, 05:36 PM
Spoonman275
Can you please tell me where you get the right size bolts and the receiver nuts at?
I just purchased some used fiberglass upper doors and do not have the hardware to install.
Please help
Spoonman275 is offline
post #7 of 7 Old 08-02-2015, 07:56 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Please help
This is a 5 year old thread my friend. The original poster hasn't been on since 2013. You could easily source the screws from a hardware store it's the little nut inserts that may be a problem. Have you tried contacting Bestop?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
Upper Door Sliders, Bestop says parts not available BLESSEDBYGOD TJ Wrangler Technical Forum 21 09-24-2013 07:12 PM
Installing Bestop Hard Upper Sliders... ??? JarWithLid YJ Wrangler Technical Forum 4 12-31-2008 06:24 PM
How good are Bestop upper door sliders LCJeep Cruiser TJ Wrangler Technical Forum 0 11-20-2007 08:34 AM
Bestop soft upper door sliders? MP Curtis TJ Wrangler Technical Forum 4 05-08-2006 04:55 PM
Bestop Upper Door Sliders ageep TJ Wrangler Technical Forum 5 02-12-2003 08:01 PM
