installing a 4" lift question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > installing a 4" lift question
Engo winches available at www.rockridge4wd.com! Free shippTJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 05-16-2006, 07:25 PM   #1
offdapath
I'm putting a 4" skyjacker suspension lift in my 94 YJ. I currently have a 1 1/4 shackle lift that I imagine I will remove and go back to the oem shackles. I was wondering if I need to lengthen my driveshafts when I do this? It doesnt say anything about that in the kit. Will the stock shafts be ok? It's strictly my tar baby. Also do I need to adjust pinion angle at all? Or just bolt thte springs up? Thanx.
94 Wrangler YJ, 2.5, 5spd, 4:88 gears, 4" skyjacker suspension lift, 2"body lift, 1" shackle lift, 33" Procomp Mud Terrains with American Racing wheels. "Built, not bought" But not without the help of Jeepforum.com
offdapath is offline   Reply With Quote
Unread 05-16-2006, 08:09 PM   #2
STP743
Drive shaft lengths are fine with a 4" lift (with or without shackle lift)
I believe your kit will include shims to go between your rear axle and leafs to help with your angles, but not sure about your kit.
2005 LJ Rubicon
on 33s
STP743 is offline   Reply With Quote
Unread 05-16-2006, 08:27 PM   #3
offdapath
do you think it would be ok to leave the 1" shackle lift in it? or would my ride be a lot rougher?
