Installed a new O2 sensor.. - JeepForum.com
post #1 of 6 Old 09-12-2011, 01:40 AM Thread Starter
Xpress
So I finally got my new Bosch O2 sensor in (I just need this thing to pass smog) and the idle seems a bit high, about 1100rpm or just shy of it. I tried pushing on the butterfly valve to see if it's opening at all and it's not..
There's no vacuum leaks either, I've verified that already. A buddy suggested that I need to run it for a bit for the computer to adjust everything properly and adapt to the new sensor. How true is this? FWIW all of the sensors (temp sensors, MAP, and even the new O2 sensor) are all working properly, and they all yield voltages/ohm readings that they should be..
I have driven it for all of about 10 minutes with the new sensor.
All about that unibody life.
Xpress is offline
post #2 of 6 Old 09-12-2011, 07:35 AM
EABiker
You can reset the ECM by removing the positive battery connection for a few minutes; always a good thing to do when replacing a sensor.
EABiker is offline
post #3 of 6 Old 09-12-2011, 02:35 PM Thread Starter
Xpress
I reset the computer by pulling the positive lead off the battery and touching it to the negative for 30 seconds, then hooked it back up, turned the key to the om position, flipped the headlights on then off, and turned the Jeep off.
Although it seems like everything is worse now. I'm pretty sure I had half a tank when I left, and 15 minutes later the Jeep had burned through at least 2 gallons of gas, and I only went 5 miles without going over 50mph...
Xpress is offline
post #4 of 6 Old 09-12-2011, 04:00 PM
oldtime_ironman
Wait, that just ain't right! I remember going through all the sensors before, and I especially suspected the MAP till you got onto the O2. I was wondering what ever happened about the T-stat? Far as the MAP goes last I heard they should vary from 0.8 to 4.8 volts depending. Man it bugs me that I can't have a look at this myself.
oldtime_ironman is offline
post #5 of 6 Old 09-12-2011, 07:24 PM Thread Starter
Xpress
MAP sensor is reading fine, and so are all of the other sensors, even the new O2, so I don't know why.
Unless it has something to do with the computer learning how you drive?
Xpress is offline
post #6 of 6 Old 09-12-2011, 07:56 PM
oldtime_ironman
Guess its possible, but I didn't think the older computers could do that. Only the ones made in the last few years. : I'm just sure there's something not right...
Speed Sensor TC 241 J from Rubi, installed in XJ REGIOMEX TJ Wrangler Technical Forum 6 08-17-2012 12:11 PM
Anyone installed a Hand Throttle WITH Cruise Controll installed also? jtice TJ Wrangler Technical Forum 29 10-03-2011 04:43 PM
ECM reset after crankshaft position sensor installed? dmw319 TJ Wrangler Technical Forum 12 10-07-2010 09:45 AM
Just installed O2 Sensor; CEL came back on. Now what? brianangst TJ Wrangler Technical Forum 11 08-13-2009 07:15 AM
power steering sensor needed? O2 sensor? Zorm YJ Wrangler Technical Forum 8 01-17-2008 09:06 AM
