Installed my lift yesturday! - JeepForum.com
post #1 of 12 Old 06-03-2002, 09:04 AM Thread Starter
Drunc
Drunc's Avatar
2.5"
Rides great, I love it
Took us about 7 hours with a dinner break in there somewhere
The jerks sent me the wrong rear u-bolts, so I had to run out and get new ones and we had to cut all the old ones off, as well as some others.
We also had to take the rear track bar and beat it with a sledge to straighten it enough that it would fit back in...
Quite an experience...next time i'll be getting all new everything
The more greif it puts me through, the more I seem to love it
Jeep: '88 YJ Laredo I6, Kenwood Deck, Amp and 6x9's, 10" pioneer sub, 2.5" Skyjacker Kit with a 1" body and new front shackles, 32" Mud Kings on 8" Desert Crawlers, CJ style replacement mirrors, ditched the trackbars and the endcaps
Drunc is offline
post #2 of 12 Old 06-03-2002, 09:14 AM
Skeeter
good job Drunc!
Skeeter is offline
post #3 of 12 Old 06-03-2002, 09:40 AM
BzJeep
BzJeep's Avatar
Congrats! My RE 4.5" should come today or tomorrow. Can't wait!
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #4 of 12 Old 06-03-2002, 12:05 PM
Plink
Plink's Avatar
Did you have to lower the t-case?
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #5 of 12 Old 06-03-2002, 08:08 PM
AllanAlxndr
Did you get any pictures of your install...
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #6 of 12 Old 06-03-2002, 09:05 PM
kidwired
kidwired's Avatar
ok now you unbolt the track bar, measure it carefully, check the tolerances and then...
THROW IT AWAY!!
now do the same with your swaybar
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #7 of 12 Old 06-04-2002, 09:32 AM Thread Starter
Drunc
Drunc's Avatar
didn't need to drop the T-Case
as far as the track bar...
Do I even need the track bar!?!?
We took it off and beat the hell out of it with a sledge to get it straightened a bit...
Drunc is offline
post #8 of 12 Old 06-04-2002, 02:40 PM
-D-
AWESOME. Love to see pics. I want to do a 2.5" with 32's on my YJ also. Seems counter-intuitive to beat the hell out of your trackbar and that it comes out straight....
Who's lift did you use?
-D-
-D- is offline
post #9 of 12 Old 06-05-2002, 03:27 PM Thread Starter
Drunc
Drunc's Avatar
I used the skyjacker kit
It was alright, except the one they sent me had u-bolts for a D44 rear end, so they were a little too big
The track bar at the rear is bent slightly, so we had to straighten it for it to fit...I'm wondering if this was even worthwhile...ie. Do I even need the track bar!?!?
I don't have any install pics...everything was VERY simple to do, I just used directions out of the Haynes Manual and the only problems I had were cutting bolts, and stupid track bars
as soon as I have a pic of the Jeep with the lift i'll scan it (I have a couple without the lift, but i'll probably wait and scan them all together)
Drunc is offline
post #10 of 12 Old 06-06-2002, 12:43 AM
kidwired
kidwired's Avatar
as i said before...junk the trac bar AND swaybar unless your going to run nascar
kidwired is offline
post #11 of 12 Old 06-06-2002, 09:08 AM
FastX
I took my track bar off yesterday and I think it handles way to loose. I can live without but it all depends on what you want to build your jeep for. I am going to order the telescoping trac bar.I just cant figure out what tires to run on my 2.5" lift. Leaning torwards 32", but how wide? I want them to stick out some.
FastX is offline
post #12 of 12 Old 06-06-2002, 02:37 PM
-D-
32's come in 10.50 and 11.50 widths right? With stock rims, 30x9.50's rub so you'll need new rims anyway. Might as well go for the wider tire then and get the right backspacing, it'll stick out some and give better traction.
I don't think 33's will fit with just 2.5" lift, not even with a 1" BL... 31's only come in 10.50.
Nice job drunc...
-D-
-D- is offline
some lift question for those who have already installed a lift jca1 JK Wrangler Technical Forum 7 10-03-2007 08:26 PM
Installed my lift.. Yay! omgsideburns TJ Wrangler Technical Forum 31 08-20-2007 11:34 AM
I DID IT! My lift is installed!!! OneCleanYj YJ Wrangler Technical Forum 15 01-22-2007 08:02 PM
Body Lift Installed, OME Lift this weekend Tenenchi TJ Wrangler Technical Forum 0 09-15-2005 04:54 PM
Picked up Rubicon yesturday JT2.5 TJ Wrangler Technical Forum 3 03-26-2005 08:17 AM
