Installed LockRight today, some lingering sideeffects... - JeepForum.com
post #1 of 7 Old 06-01-2008, 02:24 AM Thread Starter
Roach
Roach's Avatar
1. I took my drivers side brake caliper off to remove the axle and i made the mistake of loosening the brake line from the caliper, draining a small amount of fluid. when I put the caliper back on I compressed it with a C-clamp and fought with it to get it back on...now it seems to stay partially compressed, so the pads are rubbing the rotor.
2. My 4WD light won't go off - I think this is due to the assembly lube holding the locker closed, keeping tension of the intermediate shaft so the ford can't slide over...
Also, I filled the diff with heavier gear oil than what was in it.
Suggestions?
The traction is awesome by the way
Cucarachón
Roach is offline
post #2 of 7 Old 06-01-2008, 03:01 AM
CrazyCooter
If the 4wd light won't go out, you have either installed the axle shifter incorrectly. Or the vacuum lines are reversed. Either is an easy fix though.
Tony--KI6WAO
91 YJ 4.0 HO/AW4 Front TJ coil conversion
CrazyCooter is offline
post #3 of 7 Old 06-01-2008, 03:09 AM Thread Starter
Roach
Roach's Avatar
Didn't touch the axle shifter, - Didn't even have to remove the carrier. (stock gears)
and the vacuum lines weren't removed either...I don't think so anyway.
It wasn't on until i shifted it into 4WD to play with the locker.
Cucarachón
Roach is offline
post #4 of 7 Old 06-01-2008, 06:44 AM
93YJfalcon
If youre not "stuck in 4wd" (which you would definately feel with the locker) I would just drive it a bit and see if the light goes out. Since youre front driveshaft is going to spin all the time now anyway - might be a good time to get some TJ shafts and loose the disco all together. Especially if your running those 33's.
edit- Ummm. How heavy of gear lube are we talking?
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #5 of 7 Old 06-01-2008, 12:05 PM Thread Starter
Roach
Roach's Avatar
80 / 90 .
Cucarachón
Roach is offline
post #6 of 7 Old 06-01-2008, 12:18 PM
tuckinauster
tuckinauster's Avatar
Originally Posted by Roach View Post
80 / 90 .
you'll be fine
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. It’s a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #7 of 7 Old 06-01-2008, 01:16 PM Thread Starter
Roach
Roach's Avatar
UPDATE:
The brake issue seemed to be because one of the pads slipped off the retainer (inside pad toward the bottom, the clip thing was under the retaining lip on the knuckle) - I think anyway, We'll find out...
The 4WD light issue seemed to have been because it wasn't disengaging the shaft due to my posi-lock cable poking out of the back of the shift lever - d'oh
Cucarachón
Roach is offline
Installed BL today SteveJcoYJ YJ Wrangler Technical Forum 29 08-16-2007 05:55 PM
Just Installed Lockright / Comparison with Aussie bigchevyman24 TJ Wrangler Technical Forum 2 05-28-2007 08:44 PM
A few lingering front brake questions... rastadog TJ Wrangler Technical Forum 3 05-25-2007 12:46 PM
Installed BB today!! onlyone TJ Wrangler Technical Forum 16 07-17-2005 10:17 PM
RE BB Installed Today david.mciver TJ Wrangler Technical Forum 0 11-13-2004 10:32 PM
